Problem after flashing new rom Black Screen mk908 device
    i flashed a new rom this rom : MK908-ii Finless ROM 1.5a
    after plugin the device to the tv i just see a blackscreen without any boot logo or something else
    tired to flash a stock rom .. didnt work
    i would like to know if there any way to fix the problem
    thanks
    managed to erase nand
    and flashing this rom : Tronsmart MK908 Finless 1.7a
    now i can see the logo but endless boot loop
    any idea why ?
      Mine is still Blank
      At the moment I am downloading official ROM from following source:
      This is the official firmware for Tronsmart MK908. which has solved the Netflix problem, now Netflix can run without problem. You can download the firmware here: http://www.mediafire.com/download/pp2idgxuq0rl6w9/Tronsmat_MK908_android_4.2_stock_rom_official_np.rar Password: geekbuying.com Firmware […]
      Lets see how that works. I think my download speed is really slow and it will take some time to download same..
      Tomorrow going to try to switch back to Official ROM and then planning to download Finless 1.6 to see if that works.
      After i attempted to flash with 1.7a, device is not showing any output on HDMI port but Blue LED is ON.
      I can get the device is flash mode without any issues so will try tomorrow for Official ROM and 1.6 ROM.
      One query thought, How to find the hardware version for any new device..(without opening the small device) ?
      Lets see..
        My mk908v3 device is not showing any output on HDMI port but Blue LED is ON no matter what firmware i use.
        Did you find any solution with yours Sarvesh?
          Yes. .. All things open the device and see if it is real mk908... download different Roms. Try same on your device. As a last option check for original firmware with seller. Download same and that should be working.
          Sent from my GT-N7100 using Tapatalk
