2.0 GingerComb ROM + 3G stick
    Re: 2.0 GingerComb ROM + 3G stick
    OK after looking at both the stock Arnova 10g2 and the philly 10g2, I
    found many files related to 3G missing in the philly system.img. So maybe it is not just the
    kernel! We shall see... I keep my fingers crossed. If this does not work then we are stuck and I
    will have to keep working on the old kernel 2.0 ROM which I do not want to do honestly.
    OK so please follow these instructions.
    1) Take my production 2.0 gingercomb rom (not the last test ROM I just made you).
    2) Go into the image folder and rename system.img to systemold.img. This way you havea
    copy of the original system.
    3) Download this new system.img. Unzip it and copy this new system.img into the image
    folder of ther 2.0 ROM kit.
    4) Reflash the ROM erasing IDB and clicking the loader.
    Here is the new system.img with all the 3G files added.
    Man I hope this works!
    The link to the test rom doesn't work.
    There is an app called "ppp widget" to conect 3g sticks to tablets that don't support. I wonder if it will work with this test rom.
    I tested with the 2.2 rom with "ppp widget", but the app says "drivers not found". In other devices like galaxy tabs, this is solved adding the drivers files to a folder of the app:
    Could be done something similar with our arnova 1g2? Can those files be found in the original arnova 10g2 rom?
    I don't know if I'm saying stupid things. I'm Sorry, my knoledge about this is too limited.
    Thanks for all your good work.
