EKB311 RK3188_BOX_V2.0 ?
Just purchased this box. The stock firmware is a bit buggy and was looking for some roms. Seems like all the roms for this unit do not work correctly. Wifi and Bluetooth are Mediatek MT7601UN and 6622N Lan RTL8201F and the board is a RK3188_BOX_V2.0. The box has nothing on it. The back of the unit says EKB311 ENY Technology Co. Attached are some pictures of the unit. Did anyone get WiFi, Bluetooth, and Lan working with any roms for this unit? Thank you.Tags: None
Originally posted by thepczone318 View PostJust purchased this box. The stock firmware is a bit buggy and was looking for some roms. Seems like all the roms for this unit do not work correctly. Wifi and Bluetooth are Mediatek MT7601UN and 6622N Lan RTL8201F and the board is a RK3188_BOX_V2.0. The box has nothing on it. The back of the unit says EKB311 ENY Technology Co. Attached are some pictures of the unit. Did anyone get WiFi, Bluetooth, and Lan working with any roms for this unit? Thank you.Last edited by d33; 14 February 2014, 12:38.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Strongly recommend backing up your ROM first
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by neomode View Post
Originally posted by neomode View PostYes it can be made. Have you done a Rom Dump before flashing?
If yes share it with us.
Then I will see what we can do.
Neomode
Extracted kernelAttached FilesMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
No luck with kernal
Originally posted by d33 View PostExtracted kernel
Haven't heard much luck of anyone getting a working custom rom for this device.
Here is the latest rom for the device EKB311B
Developers Please Help
1. The boot.img contain an embedded kernel.
Can it be stripped so that the kernel that is already there, be used seperately for help with overclocking, vsync patch etc.
2. Can any other device's boot.img be used for this device?
3. In the init.rk30board.rc file in boot.img there is reference to the mt7601u wifi that the device uses, so another boot.img should also contain this wifi reference or file content.
4. In build.prop there is also this reference
ro.rk.bt_enable=true
ro.rk.btchip=mt6622
ro.rk.wifichip=mt7601u
5. Can someone make 720p & 1080p boot.img's and kernels, since I don't know which the stock ones are and if I mix it with other roms I just get a black screen.
6. Can this rom perhaps be modified for the Mediatek wifi above, since it's the most updated and runs on this device with the correct boot.img and kernel and changes above.
7. I also get a strong wifi connection but the internet is not working.
I read somewhere else you need to disable wifi n channel and change wifi bandwidth from 40hz to 20hz(maybe kernel or mediatek wifi chipset is incompatible with those settings) but there is no such setting in my router setup. Other dual-core TV-Sticks wifi and internet works correctly though.
Originally posted by mo123 View Post-Chromecast with Google TV
- Android Q Android 10
There are currently 2655 users online. 2 members and 2653 guests.
