ZERO DEVICES Z4C QUATTRO mini pc
    Wondering if anyone has seen or has any experience with one of these?
    asiapads.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf asiapads.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
    I've got one on the way and am hoping to get it working with a motorola droid bionic lapdock. Most obvious issue is the lapdock mini usb mount won't provide enough power for the mini pc so I'm brainstorming workarounds. Was thinking to pull more power from one of the lapdocks usb ports and to do so use (if such a thing exists?) a y cable:
    mini usb male that plugs into the mini pc's power port
    -mini usb female that plugs into the lapdocks mount
    -usb male that plugs into the lapdocks usp ports
    z4c specs pulled from the above link:
    Features:
    • OS: Android 4.2.2
    • SOC: RockchipRK3188
    • CPU: ARM Cortex A9 Quad Core 1.8Ghz
    • GPU: Mali 400 Quad Core
    • Memory: 2GB DDR3
    • Storage: 8GB NAND Flash
    • WiFi 802.1 b/g/n
    • Bluetooth 4.0
    • WiFi and Bluetooth based on Broadcom solution
    • Flash 11 / HTML5
    • Size: 89x30x15mm
    • Multilanguage
    Conections:
    • 1 x Standard USB
    • 1 x Mini USB
    • 1 x Mini USB for power
    • 1 x TF Card slot (up to 32GB)
    • 1 x Mini HDMI
    Audio / Video:
    • Video: WMV, ASF, MP4, 3GP, 3G2M4V, AVI, MJPEG, RV10, DivX, VC-1, MPEG-2, MPEG-4, H.263, H.264, 1280x720 HD 30 fps, 1080p/720x480 D1 30fps
    • Audio: MP3, WMA, APE, FLAC, AAC, OGG, AC3, WAV
    • Pictures: Max 8000x8000 JPEG, BMP, GIF, PNG
    Content of the box:
    • 1 x ZERO Devices Quattro (Z4C) ORIGINAL
    • 1 x ZERO Devices Super HUB (3 USB + 1 LAN) (OPTIONAL)
    • 1 x ZERO Devices box
    • 1 x AC Power supply 120~250AC - 5V - 2A
    • 1 x USB to mini USB cable
    • 1 x HDMI to mini HDMI cable
    • 1 x Mini USB to USB standard adaptor
    • 1 x Mini CD manual (english)
    • 1 x Awl for firmwre uploading
    • 1 x ZERO Devices Athenticity Card with unique and registered serial number
    Any thoughts would be much appreciated as this is really my first project of this sort and only my second android product. I'll let you know my thoughts on the device as it arrives.
