KitKat runing on old mk802iv
I found wasser's KitKat ROM for MINIX x7 with kernel k-r42 very nice and steady work great with beyond xbmc WiFi stable no BT though and was not able to of the kernel with overclockomatic but still got 17369 with antutu and I had to share the joy here's the thread
Tags: None
Originally posted by doirizarry View PostI found wasser's KitKat ROM for MINIX x7 with kernel k-r42 very nice and steady work great with beyond xbmc WiFi stable no BT though and was not able to of the kernel with overclockomatic but still got 17369 with antutu and I had to share the joy here's the thread
http://www.freaktab.com/showthread.p...2-for-Minix-X7
how to flash this rom and the proper kernel?
thanks
KitKat
thanks
If xbmc is a must, Beyond XBMC Beta 2.9 (GT-I9300), is what I got on mine thanks to flumpster you can find it here http://www.freaktab.com/showthread.php?9603-Beyond-XBMC
Originally posted by doirizarry View PostWere you able to install the ROM? Are you mainly going to use it for xbmc?
If xbmc is a must, Beyond XBMC Beta 2.9 (GT-I9300), is what I got on mine thanks to flumpster you can find it here http://www.freaktab.com/showthread.php?9603-Beyond-XBMCTo Infinity and Beyond.... XBMC
The KitKat ROM from wasser firmware, is one of the best roms that I used in mk802IV. The wifi is perfect, but I have a problem with audio syncronization in some video applications.
For example the application "mitele" has 2 seconds of delay between the audio and the image.
Do you have this issue?
sound sync
Originally posted by querol View PostThe KitKat ROM from wasser firmware, is one of the best roms that I used in mk802IV. The wifi is perfect, but I have a problem with audio syncronization in some video applications.
Checked out mitele have your same problem but found mywebtv addon for xbmc might be a solution to you problem let me knowLast edited by doirizarry; 20 February 2014, 23:12.
I'm glade I was of not helpdid do some looking for tv live streams with not much luck, if it worked to any degree the sound was bad and the video was at best "choppy" until I tried tvalacarta and tried one looked nice and I didn't know they had live streams on that xbmc addon thanks for sharing
There are currently 1782 users online. 1 members and 1781 guests.
