Sent from JB 7+ using tapatalk
Lava Xtron+ RileyROM 1.1
32gb is your external SD limit. If you use an external HD, it must have its own power source...the tablet won't run it. Same with some thumb drives. I have had luck using a powered USB hub for all of that.Randy
Like I said in post #18, you are limited to 32gb on the external SD.Randy
Originally posted by ukstillalive View PostIs there any way to run 64gb card ??? @riley
If anybody with working rooted stock with working video can upload the ROM it will be great...Last edited by Anthrax; 10 May 2014, 13:12.
I can't find that original firmware file anywhere.
If there is a new factory firmware update, send me a link...and I can make a new ROM. Otherwise, there's not much else I can do with it.Randy
PLZ HELP
Originally posted by rrileypm View PostThis ROM is based on the same ROM dump I used for v1.0, but I had to help out a user with a problem with v1.0 and decided to update it a bit.
I've updated my process quite a bit since July, when I released v1.0 and I've added some new features.
Auto Install Feature: This allows you to install apk's automatically on first boot, if you have the apk files located in a folder named autoinstall on your external SD card. See this thread for details on this feature
Otherwise, this ROM comes with the usual latest RileyROM features:
Rooted with SuperSU
Debloated of all Lava bloatware
Google Play Store tweaks added to improve availability of apps
Init.d support
Busybox support
English language default (all other languages are still supported)
Boot screens by Tattman65
Flash Tool by Finless
Reboot app by Petrus
Download
I don't normally provide an update.img version of my ROM's because it limits your choices, but for this particular ROM...I made one for a user who can't flash from Windows. Here's a link to an update.img version: Download
Enjoy!!!!!
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
I WANTED A ORIGINAL ROM OF THIS LAVA XTRON PLUS TABLET AS I CHANGED THE BUILD.PROP
FILE.
AND NOW MY TABLET STUCKS AT BOOT SCREEN
I TRIED DELETING CACHE AND DATA(FACTORY RESET) BUT IT DOESN'T HELP.
PLZ GIVE ME A ORIGINAL ROM AND HOW TO FLASH IT USING PC.
THANKS IN ADVANCE!!!!
help
Could u plz giv a responce
There is no stock firmware published for this tablet.
What I've sent you is a ROM kit with the dumped files I based my ROM on.Randy
There are currently 6795 users online. 0 members and 6795 guests.
