I'm new here and I'm unsure if this is correct sub-forum to post in, but since I own a Minix X7 I hope I'm right here (if not, please move the thread).
I found the Cloudproject PocketKey Kitkat Rom at http://cloudproject.freeforums.org/k...ey-rc2-t3.html and I wonder whether it can be used on the Minix X7.
Judging from the rom and the specs it should also use the RK3188 platform.
I extracted the rom using the firmware tools from http://www.freaktab.com/showthread.p...Firmware-Tools . I noticed the bootloader is different (extracts as RK3188Loader(L)_V1.20) and I don't think I should use it on the Minix, since I might brick it, right?
Apart from that I noticed, that the parameter file only contains a userdata partition, but no user partition, so it seems it uses the new emulated internal SD-card feature introduced in Android Honeycomb. Kernel seems to be 3.0.36+.
I thought about keeping my current bootloader (2.08) and the kernel from wasser's Kitkat release and flashing the rest, but I'm unsure if that will brick my device.
Anyone willing to have a look into the rom and maybe modifying it for the Minix X7? Or at least hint me to what I have to modify to try this rom safely.
