I connected it to my lap top pressed the select and start button laptop went bing and now the gamepad will not turn on no led lights and when I connect it up the laptop it says no drivers found , have I blown the control panel or fuse in side ?? Or can I fix this ??
G910 gamepad
G910 gamepad
Hi guys , this is my first post so I hope it goes correct i recently received my minix x7 and g910 gamepad
I connected it to my lap top pressed the select and start button laptop went bing and now the gamepad will not turn on no led lights and when I connect it up the laptop it says no drivers found , have I blown the control panel or fuse in side ?? Or can I fix this ??Tags: None
Originally posted by Buster86 View PostHi guys , this is my first post so I hope it goes correct i recently received my minix x7 and g910 gamepad
I connected it to my lap top pressed the select and start button laptop went bing and now the gamepad will not turn on no led lights and when I connect it up the laptop it says no drivers found , have I blown the control panel or fuse in side ?? Or can I fix this ??Get 15 GB Free Cloud Storage on Copy.
https://copy.com?r=ihG93E
G910 gamepad
I up dated the firmware and drivers , I used the USB cable to connect it to the lap top , every time ya use it even with the same device ya need to un pair it and repair it and it won't work with all the games on the minix x7 unless you root ur device , and will only work with some Icade games on iOS and for android tablets / phones ya need to map the buttons , very frustrating a simple explanation could of save me loads of time
Motorola Razr D3
Originally posted by Buster86 View PostIs it fully charged? Are the lights blinking fast or slow ? Have you up dated the firm ware ?
Fully charged. Blink fast. I update the firmware and i can pair in APP mode (Y+home), work good but dont pair in gamepad mode ( X+Home).
Originally posted by Buster86 View PostAfter a long time i have managed to understand how it works and have it working now
I want it for my Minix Neo X7, i have a windows 7 64bit machine that doesnt see the controller when plugged in.
Any help would be appreciated.
Originally posted by Buster86 View PostUr minix will have to be rooted for it to be used on all games , if you have the firmware install , knock off the bluetooth on ur minix and knock it back on then turn ur g910 on and press y+home and it should connect
The minix is rooted, so no problems there. But the unit shows no lights when you turn on it on..... It happened i unsuccessfullly attempted a firmware update.
Thank you anyway.
There are currently 2335 users online. 0 members and 2335 guests.
