Bricked X7 ???
    Bricked X7 ???
    Hi Everyone.
    I have been trying a number of firmwares from here on my MINIX X7 box.
    I tried Kitkat 4.4.2 and was having problems with wireless connectivity, so I tried JustXBMC.
    This is where problem started, I erased IDB and then flashed firmware, it got to about 40% then I got a failure message. Now I cannot erase IDB as it gets to 677 then states
    lower format failed
    Erasing IDB failed
    Is there a solution
    I've flashed quite a few different android boxes, tablets, and I have never come across this before
    Do you also have the problem that the USB connection with the PC is lost after a few seconds?
    When I returned from 4.4 to 4.2 I also semi-bricked it, solved it by taking the next steps:
    1. Put something in the recovery hole to press the button inside, and keep it pressed.
    2. Press and hold the powerbutton so the device goes into recovery mode
    3. Flash a new firmware
    (Remember to keep both buttons from step 1 and 2 pressed during the whole process, so even when you're flashing they should still be pressed!)
    Hope this helps!
      I got random problems while flashing when I had a long usb cable. Try a short one.
      Sent from my Nexus 7 using Tapatalk
        Hope this helps!
        Thank you so much
          this should be sticky as I saved my minix with this procedure too....
            Excellent.
            So simple yet so impossible to figure out yourself.
            I agree . Should be sticky.
            Thanks this saved my x7
              Originally posted by leeflump View Post
              Excellent.
              doesnt work here. All i get is test device failed. even keeping the pin pushed in and the button pressed
                Hope this helps!
                +1 on this. I found that just keeping the power-button in, releasing only the recovery button, also works.
                  Excellent.
                  Mine too.
                    Hope this helps!
                    You are a life saver
