power supply for TV01 aka CS968, and CR11s
After suffering through too many freezes and reboots, I finally decided to get another power supply for my TV01 android tv box from geekbuying. I had tried every rom available for this box but none of them solved the reboot problems for me. Seems like everyone on this forum says to replace the power supply as last resort. No problem, just hop on to amazon and get one, wrong, not that easy. I would have thought that a power supply with specs of 5vold 3 amp would have the same connector, NOT. At least most of the descriptions had a size specified for the connector. Could not find my micrometer, so had to use my trusty old scale in metric. With my old and bad eyes, I could get an approximate estimate on the dimensions. First power supply I ordered had the wrong connector, gggrrrrrrrrrrrrrr.. Ok, using the specs of the wrong connector, I was able to find the correct power supply. However, the correct one, has a 90 degree connector instead of a straight one, but it does work. So, to make a long story short, if you need a new power supply for your TV01 aka CS968 then this power supply will work. It is a little heavier, which is good, than the one that shipped with the box. Btw, most of my reboots and freezing have stopped. Still have a few every now and then, but not as bad. Anyway, here is a link to the correct power supply that I purchased. It has the US prongs.
MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68Tags: None
Originally posted by clarkss12 View PostAfter suffering through too many freezes and reboots, I finally decided to get another power supply for my TV01 android tv box from geekbuying. I had tried every rom available for this box but none of them solved the reboot problems for me. Seems like everyone on this forum says to replace the power supply as last resort. No problem, just hop on to amazon and get one, wrong, not that easy. I would have thought that a power supply with specs of 5vold 3 amp would have the same connector, NOT. At least most of the descriptions had a size specified for the connector. Could not find my micrometer, so had to use my trusty old scale in metric. With my old and bad eyes, I could get an approximate estimate on the dimensions. First power supply I ordered had the wrong connector, gggrrrrrrrrrrrrrr.. Ok, using the specs of the wrong connector, I was able to find the correct power supply. However, the correct one, has a 90 degree connector instead of a straight one, but it does work. So, to make a long story short, if you need a new power supply for your TV01 aka CS968 then this power supply will work. It is a little heavier, which is good, than the one that shipped with the box. Btw, most of my reboots and freezing have stopped. Still have a few every now and then, but not as bad. Anyway, here is a link to the correct power supply that I purchased. It has the US prongs.
https://bixmart.3dcartstores.com/5V-...mm-_p_158.html
I Made My Own Power Supply, Had An 12V 3A Lying Around, Replaced 2 Resitor's Walla It's Now 5v 3a,
Work's Perfect.
If Any One Need's Help On This Kinda Thing Ask Me...
Re: power supply for TV01 aka CS968, and CR11s
Please help me. I bought DC step DC converter. But I need help on connecting this . I opened the stock power supply and wanted yo use the casing.
OK now in the new unit it shows IN+ and IN- but the old one connected to N ,L. Now I want to remove the DC connection to insert it to the new board. Is it OK to connect any wire to IN+ and IN-. Or is there any conditions. Please see the attached picture.
Sent from my GT-I9300 using TapatalkGet 15 GB Free Cloud Storage on Copy.
https://copy.com?r=ihG93E
Originally posted by lionsl2005 View PostPlease help me. I bought DC step DC converter. But I need help on connecting this . I opened the stock power supply and wanted yo use the casing.
OK now in the new unit it shows IN+ and IN- but the old one connected to N ,L. Now I want to remove the DC connection to insert it to the new board. Is it OK to connect any wire to IN+ and IN-. Or is there any conditions. Please see the attached picture.Sent from my GT-I9300 using Tapatalk
Boss This One Is DC/DC Converter.
This You can't Use Main's On This, I Repeat Don't USE IT..Last edited by whocares; 19 February 2014, 10:26.
I wanted to use this one for my imito qx1.
Thank you so much.
PS
I used a dlink PS that came with a barrel connector. just cut that off and spliced in a usb cable. Now, I found mine in one of my junk boxs. But , I see they have them on amazon and e bay. There a good quality PS. I use it on a overclocked cx919. While I was at it. I also tore off the cheapo aluminmum heat sink and replaced it with a fan off a old graphics card. The PS powers the fan too. Have had no reboots since then.
There are currently 1683 users online. 1 members and 1682 guests.
