Ready to update my Minix X7 rom...But to which one? Help please!
    So I've held off updating our X7 for long enough, and need some input from other users on which one they feel is the best! Although I will take any suggestions into consideration, I'd prefer replies from users who have used at least two of the top four or five from here or Minix's latest stock firmware. Mostly I use ours for XBMC, which I'll probably be using Beyond XBMC, Netflix, Hulu+, Google Play Movies, and Music. Thank you and I'm looking forward to replies! Btw, I have read through most of the forums, and have read good and bad things about them all. So I'm trying to narrow it down! Right now I'm leaning towards Wasser's 4.4.2, unless someone can change my mind! Thanks again!
    I sugest you this one:
    Minix X7 Hybrid Firmware (HFW) 3.2 by lewy20041
    For sure is the fastest and most stable for Minix NeoX7.
    http://www.freaktab.com/showthread.php?9083-Minix-X7-Hybrid-Firmware-%28HFW%29-3-2-by-lewy20041
    Best regards
      Best regards
      Thank you! I'll check it out!
        I agree the best rom out there.
        Best regards
          As for every Rom you can't say this is the best. What for one is suitable the other is not.
          I have very good experiences with the Hardwareguru Rom. Only I have a thing on passthrough and my receiver.
          So I am now on Quickshot again. Which don't have this problem.
          So try some roms and look which you suit the most.
            Re: Ready to update my Minix X7 rom...But to which one? Help please!
            All custom roms have something special, for me there is no one better than other, and more customs, more choice for users, I usually try to test all of them, and I use the one who fits to my needs
            leolas.
            My devices:
            Gearbest.com)
              Thank you for the replies! I'm currently on Quickshot V2 which is running great! I tried the Kit Kat rom and had problems with it getting a long with my tv, air mouse, and usb mouse. But I still want to try it, possibly gonna try some different kernels.
                Owww so you are flashing your a** of at the moment.
                Good luck in the search.
                  Lol welk first I had to figure out how to use the RKAndroidTool with Kit Kat because you have to replace files, but figured it out quick. First I tried the 720p kernel that has working BT, which both of my mouses made it freak out, and screwed up my tv screen image. Then I tried with the stock 720p kernel with the same results. Flashed Quickshot V2, and all is good! So now I'm thinking about trying the 1080p kernel with working BT on the Kit Kat rom. I would flash the rom suggested above, but I'm satisfied with Quickshot V2 for now. So it's either that or Kit Kat for me.
