Onda v975m
    Originally posted by d33 View Post
    Written
    Thanks for the review, sounds attractive
    Using my ipad so apols for any stupid ios spelling 'corrections'
    It's a great bit of kit, very well made too - just some firmware/software niggles.
    I was wondering, as you are going to have a look at the S802 based ROM for the M8/S89, if you might have a peep at the v975m ROM? Should be very similar in many respects.
    Surprisingly cheap for what it is!
      ondaforum previously v975m com forum
      v975m.com and its forums have moved, and changed its' name..
      With hopes of providing a forum for most Onda Tablets, currently available and future releases.
      The new address is http://www.ondaforum.com/.
      A new look, a new feel. Everything accessible through the landing page.
      No more separate log in requirements for Home Page, Downloads or Forums.
      Members may soon upload files directly to the server.
      Please express patience during the changeover and as the site continues expansion.
      All v975m.com member log ins remain the same, new members welcome
      Private Developers Area available to promote development collaboration, testing and exchange
        Has anyone recovered a bvricked v975m yet? I bricked mine after a week and have made a few atemts over the last three weeks to bring back to life. No luck with the SDCARD apps from Finless.
        Is opening and shorting NAND the answer?
        Donate to Finless
          Opened up shorted pins with 'special' formatted SDcard inserted and no joy still totally dead, no leds light, no screen flicker no nothing.
          Donate to Finless
            Check site - Custom ROM discussions - Lead post ( by Rozak ) is his usual placement for all up to date changed files, instructions, etc
            Several questions to prepare you and help you decide, to select proper suggested solution ...
            V1 or V3 ? / ROM version installed ? Last known good / running version ( custon or Onda or ? ) What version do you choose to be install ?
            Several have had success .... a few failures .... Patience and try to stay in proper thread if / when you post anywhere
            China BBS sites been hitting site heavy for Rozak stuff and assistance, for past 48 hrs
            Good Luck, and hope to see you there
              Took me over an hour to get it back last night!
              Sorted it out got it functional again. Then started playing with custom tools and bricked it again
              I'm getting quite good at restoring now!
              For others who have the same problem, these tools are useful
              Donate to Finless
                Hmm... thinking about this one...does it have Bluetooth?
                https://public.bay.livefilestore.com...ion.png?psid=1
                  There are two versions, V1 does not have Bluetooth, while V3 does. Mine is on the way
                  Inviato dal mio HTC One S utilizzando Tapatalk
                    Such good hardware specs ... and then there's the Onda ROM.
                    It seems with every new Onda ROM release, they create more and different hardware issues.
                    It seems the 1.1.0v3 issues are reminiscent of previous v1 ROM issues.
                    Need developers for this kernel , Amlogic M802 and Onda ROM specific.
                    http://www.ondaforum.com/ a site dedicated to be a central location for current and future Onda tablets
                    Edit 26Apr2014
                    Thanks to everyone here for all your continuing help. I remain humbled by all the experience you share and guidance you provide.
                    Thanks to Finless Bob for helping me better understand and permitting other site info post.
                      (Onda V975)
                      ok
                        R: Onda v975m
                        Originally posted by Sigismundpower View Post
                        Honestly, very weak tablet (Onda V975) in some ways! Strongly heats the 40C-45C cover. The battery can hardly 4-5 hours. Only I have this problem? The ruins can not handle this fine resolution. Pipo tablet stand is much better.
                        Well, ONDA v975 and v975M are two completely different things, and the latter is quite good!
                          onda v975m V3
                          Can you help . i have the same problem. can you give me a details how to do? step by step. sorry on my english. onda tablet is dead. screen is blank. only spu is warm.
                          and which opereting system must i have winxp,win7,win8 ,32 or 64 bit,
                          Thank you very'd appreciate your help
