Pipo M9 MAX KitKat 4.4 stable
Originally posted by Bunny View PostLook like the M9 MAX got KitKat at last. Anyone try it?
http://vitha.forumotion.com/t177-pip...-kat-44-stable
We just need more enthusiasts that would be willing to work on it and improve it..
Originally posted by jninanyac View PostI would like to try it, but I don't see where are the download links. If someone help me I can give some feedback.
Anyway I would like to try, but my pipo is not able to connect with my PC on refresh mode, so I think I must be live with the stock rom.
Originally posted by Bunny View PostYou must be a registered user (free) for see the link. I think this forum is same as the most of them.
Having the chance to switch to a custom ROM and staying with stock is a waste of a tablet
Originally posted by babyboy3265 View PostWhat do you mean your not able to connect it in refresh mode? What do you mean by refresh mode?
I have a root-ed and cleaned stock rom, its working perfect. It would be nice to refresh but not the world biggest problem.
Originally posted by Bunny View PostIts mean I can connect on mass storage or ADB mode perfect, I can copy files, I can rooting etc, but the flashing programs do not recognize my tablet. Yes, I using the original long head cable, and yes I installed the correct drivers. I have no idea why it is not working. I did connection in the past, but some months ago I buy new motherboard and reinstall win, perhaps that is a problem.
If yes try another PC... Sometimes PC's are the problem when a connection doesn't work properly..
Good luck and write your solution here if you find oneWe are the android community, we need to spread the knowledge for those who may one day need it, the way we all did once
Originally posted by babyboy3265 View PostWhen you try to connect do you turn USB DEBUGGING on?
I follow the rileyrom introduction, then I try every possible version debugging on/off, etc-etc. I spend a whole day for testing different version of programs, drivers and possibilities then I just give up. Maybe some one more clever then me saw the same problem and found solution.
Anyway thank for you to try help, but this is offtopic here, and I try to found solution in this forum without success a few months ago:
Originally posted by Bunny View PostI follow the rileyrom introduction, then I try every possible version debugging on/off, etc-etc. I spend a whole day for testing different version of programs, drivers and possibilities then I just give up. Maybe some one more clever then me saw the same problem and found solution.
http://www.freaktab.com/showthread.p...em-with-update
Originally posted by santini View Postmaybe the problem is your mobo has usb 3.0 ports: Try it on a computer with usb 2.0 and see if it works
Originally posted by nfccristo View PostHello guys, my english isn't good, but I'll try to put my doubts.
In the step 10 (install Oma RK31 KK v2.1 Format NAND.zip from ext_sdcard), my tablet can't mount the ext_sdcard.
What is the problem and what can I do?
I have Riley Rom 2.4
First, please don't mix discussion about other ROM's in a different ROM thread. It's a little confusing when trying to offer suggestions. That question should be in the RileyROM 2.4 thread.
Second, I've found that KitKat doesn't play well with NTFS...and neither does TWRP. While NTFS provides better protection against corruption, FAT32 is required for these KitKat ROM's.Randy
Originally posted by rrileypm View PostFirst, please don't mix discussion about other ROM's in a different ROM thread. It's a little confusing when trying to offer suggestions. That question should be in the RileyROM 2.4 thread.
And I wanted to say that before flashing KITKAT the tablet was in RilleyRom 2.4.
Anyway, since I solved the problem through an SD memory card.
Thanks for the replies and sorry for the mistake.
There are currently 3049 users online. 1 members and 3048 guests.
