autohide system tray in Quickshot FW BY NitroTeam
hi,just installed the QuickShot_v2 firmware,works fine so far except occasionally crushes and had to pull power cord off to swich back on again,can't figure how to enable autohide tasbar n XBMC and other appications,I've ticked the option in Settings but won't work,please help.I'm using Minix Neo X7.Tags: None
Re: autohide system tray in Quickshot FW BY NitroTeam
Originally posted by alinuk05 View Posthi,just installed the QuickShot_v2 firmware,works fine so far except occasionally crushes and had to pull power cord off to swich back on again,can't figure how to enable autohide tasbar n XBMC and other appications,I've ticked the option in Settings but won't work,please help.I'm using Minix Neo X7.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostAutohide will not work with launchers, if you install the xbmc launcher version, then that is why, by default the Rom comes with xbmc launcher version, uninstall xbmc and install beyond xbmc 3.3 by flumpster.
leolas.
Originally posted by alinuk05 View PostThnx for your replay,I will try the version you mentioned,any down.links?also do I really need to unnistall the pre-loaded version as this works perfect after I've tried various Rom's..Thnx.
There are currently 2402 users online. 1 members and 2401 guests.
