How to install adobe flash player in picuntu 4.5?
    As the topic states, I want to know how to install flash player in picuntu 4.5 running in MK908II.
    I have been doing some googling & searching around but unable to find any proper solution.
    Found one that says about making flash run in chromium, but I need flash running in Firefox.
    Have tried some flash libraries, but unable to make it work.
    Any help would be appreciated.
    Thanks!
    Thanks!
    You can use gnash with firefox, is a good replacement. If you can use chromiun, you can use full flash suport through Pepper flash for chromium:
    Download:
    Extract an copy the folder PepperFlash inside of usr/lib of file to your system /usr/lib,after the PepperFlash plugin will be in : /usr/lib/PepperFlash/libpepflashplayer.so
    So edit the file: /etc/chromium-browser/default
    change chromium config flags the text like this:
    CHROMIUM_FLAGS="--disable-accelerated-compositing --ppapi-flash-path=/usr/lib/PepperFlash/libpepflashplayer.so --ppapi-flash-version=11.7"
    And open chromium, now you have a powerfull chromiun with flash player 11.7 full suported.
      Need flash in firefox and not chromium
      Originally posted by jakson View Post
      You can use gnash with firefox, is a good replacement. If you can use chromiun, you can use full flash suport trouth Pepper flash for chromium:
      Download:
      As mentioned in my original post, I have found about flash running in chromium, but I need it in firefox.
      And gnash doesn't work for everything, particularly the app I need.
