Official FW For CS968 Siqi Model (CR11s)
    Nop
        Links Updated In First Post....
          This version is really smooth, is the best rom that i've tried for cs968!!
            MBOX Firmware
            Noob here,
            Anyone has the original ROM of MBOX for cs968 my board is htc_t018 v3 MTK. Thank you. it's build date is 12252013. I just installed the new firmware 02252014. it's true it does very smooth..., but antutu give me 15455 while in the rom before, it gives me 15888. thanx.
              Originally posted by pincer View Post
              Noob here,
              Why would you revert to an old firmware just because a benchmark was 2,5 percent higher.
              You can assume the new firmware fixes soem problems that were in the older version, You say it runs really smooth.
              If it was 20 or 25 percent I would understand, be 2,5 percent is nothing. Could just be variaton in the benchmark.
                Still, doesn't hurt if you have the origin ROM though. Btw, I found that, beside re-plugged your power, you can also re-plugged the HDMI cable to turn it on. 'course from power off mode. Cheers..
