He said It always "kick me out " when I am not doing something on the program . The tv says no signal. I have to reboot it all the time .
X7MINI with quickshot v2 sleep issues
I seem to have a issue with this box going to sleep. The person who has the box says that if they dont use it for a few minutes the screen goes black tv says no input and they cant get it to turn on again without unplugging.
He said It always "kick me out " when I am not doing something on the program . The tv says no signal. I have to reboot it all the time .Tags: None
the problem can be generated if you install a app and if this app has settings like "let the screen on if ...". If you are setup this app you can deselet this functtttion in android settings.
rlemke | www.humaniac.wordpress.com | www.minix7.wordpress.com
Ask this person which app installing at last and looking to the settings of this app. If you move the cursor the box will go not to sleepmodus.
Re: X7MINI with quickshot v2 sleep issues
Try in settings, disable in usb the option connect to pc.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2179 users online. 0 members and 2179 guests.
