M9 flash problem
    M9 flash problem
    Hi !!
    I've tried to flash my pipo M9 with several different roms but i struck out.
    All i get is a black screen and the flashlight turns on, but i can see that it turns on, but there it stops.
    I have tried using both rkbatch tool and flash tool. Both off them complete without errors but it wont start any way
    Can somebody please help me ?
    //Jimmy
    Is it your first try to flash your Pipo ? And use you the right Rom?
    If you have a pipo m9 you can't use the roms from a pipo m9pro
    First flash a original rom from pipo that is specifically for your tablet and
    If that's works try a other one.
    Joerg from Germany
    Gesendet von meinem M9pro mit Tapatalk
      No, it´s not my first time. And yes it´s the rigth rom.
      I´ve tried 2 more today, and now i get to boot screen, one small step forward.
      I time i go stuck on the cwm and its said it coludnt load from e:\
      I saw the little fix from riley about misc, flashade it and i got to boot screen, but no more.... grrrr
        Finally my Pipo is up and running. The rom that is working for me is Pipo_M9_wifi_4.2.2_RileyROM_1.9a
        Can someone please speculate what im doing wrong to get 1 out of 10 roms working for me ?
        //Jimmy
          Double post
            U flashed with wrong ROM
            If your tablet is M9 (not pro) u flashed Pro version. U must to flash M9 version of ROM. click on reset wiith cliked esc and power and when comp bigin to determine your tablet, u can to flash correct ROM.
              When you are sure you're using the right roms and they downloaded right, make sure you use the original or a decent usb cable to flash.
              I suppose that could also be the culprit of bad flashing.
