GamePads compatible with AMLOGIC MX Boxes
Unfortunately, this did not work.
Closest I've gotten yet though.
OpenPad Union sees the pad.
BitGames IME shows up in the input settings screen.
The pad's red light button for toggling anologue stick lights up.
When I connect it, I get the message
connect to dev/bus/usb/002/005
When I try to set up the config manually in RetroArch, it doesnt recognise any buttons when in connect mode.
Just found a UGA Wireless PS3 pad with a USB dongle. Gonna give this a bash.
That didn't work either.
Finding that I'm having to reset to factory settings after every configuration I try in OpenPad Union as the box just seizes up a lot once ive tried to assign a gamepad.
I love these Amlogix MX Tv Boxes, think they play XBMC better than anything I've ever had - but it looks like they're totally useless for emulators.
Originally posted by skelton View PostProbably the kernel of the amlogic box has not the modules needed to run gamepads,
Which is the amlogic box and which kernel version is using? Using generic MX 3.0.8 or 3.0.50 amlogic source should be enough to compile several modules and load them via init.d for instance.
can you guide me on how to integrate hid-dr.ko modules into Android TV OS 12 kernel??
i have init.d support ROM, but somehow it refuse to run on some point..
and when i do force integrate using script manager, it get error "insmod failed to load, exec format error"
i have no clue anymore.. ??
There are currently 1818 users online. 0 members and 1818 guests.
