Any ideaS?
mk809ii rebooting
Originally posted by ricflairandy View Post\
Not overclocking jus tstandard. I use the standard psu i had. Could i try an ipad one ?
You do need one that will provide at leas a reliable 2A of power minimum... the problem is that most PSU's that come with these devices ( except perhaps the high end ones ) can not provide the power they claim. So even if you buy a cheap one marked as a 2a... it still may not be able to provide good enough power.
All is in Power!
Originally posted by ricflairandy View Posthi i have tried 3 finless roms and every time the device will reboot randomly. All i am using is a usb mouse and i am using the power sipply for usb.
Any ideaS?
My two MK908II from Tronsmart it always started up again, but when I put a good 4A power supply, everything went ok.
NB: 2A for MK908II is not enough, sometime he exceed 2.8A.Bonjour! Je suis de Shawinigan, Québec, Canada
Originally posted by Lovebaned View PostMy two MK908II from Tronsmart it always started up again, but when I put a good 4A power supply, everything went ok.
Originally posted by rdsok View PostYeah... but the MK908II is a RK3188 Quad core.... this is the MK908II which is a RK3066 dual core CPU
MK908II doesn't exist with an RK3066. The device that you say is probably a MK808II.It is the same device with only the Processor that change.
There are currently 2260 users online. 0 members and 2260 guests.
