So you found all the tools on this site eh?
Help: Nooby guide for MK902
Originally posted by scooter2014 View PostYes Neomodes thread has it all
http://www.freaktab.com/showthread.php?10775-RKM-MK902-Neomode-Custom-Rom-Version-1-0
Of course, thanks to Neomode for making the Custom ROM available. It still leaves us waiting for an answer to the thread topic.
It's good to be alive!
Originally posted by FlyNNN View PostIt took a month and the best we get is a cryptic answer. Better than nothing. This community is severely lacking when it comes time to lending a helping hand. Where are all the experts following the Neomode thread? Couldn't care less about anyone new who stumbles across Freaktab.com looking for answers. For those who come across this thread in the future and how it should be done, here's a link to get you started. Don't expect to much, after multiple pages of posts, there's really no instructions on how to implement the ROM;
Its all there in black and white and your able to press the search button too, when doing so read the forum rules as it states there to read then read again. If anything is lacking its your manors had you asked for a link I would have provide as your new here and maybe didn't see the search button at the TOP of the page,
Last edited by scooter2014; 14 March 2014, 01:22.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
ok go to the link above download noemode rom. un zip it and then go to post 81 download the kernel there.
Then open the rktool in the rom, set pin on side near wireless antena at same as plugging in the usb into the post beside the sd card. The tool should say (found rockchip device) You dont have to change anything here except the KERNEl you can use anyone of the ones provided by neomode by selecting the 3 buttons at the side on tool where it says kernel. they are oc and t or non t related. They are located in the file rock development image folder. once you click the 3 dot beside the kernel it will open window to select file.
( keep in mind these are oc kernels so some may or may not work depending on limits of your chipset. )
Or you can select the kernel where you downloaded from post 81 as its stable and working fine. select the kernel of your choice then select erase idb soon as that finishes select run. it will flash the rom and your good to go dont un plug or touch till it finishes.
Edit- if you select nothing it will install the 1.6 Kernel from Neomode if i am not mistaken.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostThen open the rktool in the rom, set pin on side near wireless antena at same as plugging in the usb into the post beside the sd card. The tool should say (found rockchip device) You dont have to change anything here except the KERNEl you can use anyone of the ones provided by neomode by selecting the 3 buttons at the side on tool where it says kernel. they are oc and t or non t related. They are located in the file rock development image folder. once you click the 3 dot beside the kernel it will open window to select file. ...
This site is a disappointment. I have since found more information/participation elsewhere. Scooter seems to be elsewhere as well. I did find this link that should finally answer the thread topic;
http://chinagadgetsreviews.blogspot.ro/2014/03/video-tutorial-how-to-install-stock.html
Hey sorry i am here every minute but i do respond to every im i get,that site explains how to do a normal rom change not how to install a custom rom from neo or other but with that aditude ill be not getting to much of a response as everything you asked its easy to find and sorry but i am sure if you where having problems and after reading all the posts for custom roms you will figger it out. if you run into an issue ask but again it is all on this site>Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
http://www.freaktab.com/forumdisplay...V-MK809III-etc This is a good starting point a lot of good roms for the 902 here and they are very good. its best to read each one and what changes they have so you can pick best one for your needs. good luck and if you run into a road block or cant figger something out just im me.
regards.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by FlyNNN View PostScooter, you misinterpreted my post. No need to apologize. I meant no disrespect to you, you have been helpful.
Thanks just testing new rom for the 902 so kinda gt focused ob task at handMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
https://plus.google.com/app/basic/st...nsiqvabtvtpe04 how too on neomodes rom sorry i got busy.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 1839 users online. 1 members and 1838 guests.
