PIPO M9 Pro Problem with freezing & Wifi reconnect
    I hope this the proper place to post these questions I have since I am new to this forum.
    First Bacckground:
    I got an M9 Pro two months ago. It has caused nothing but problems. I tried to fix it by removing the Chinese bloatware & flashing the rom with Finless 1.5. This fixed nothing. I do not seem to have a GPS problem. I have not yet checked the bluetooth. I know it didn't like the micro sd card at all. Along with the terrible WiFi problem, the tablet freezes up on games. I have 3 games by GameInsight & 1 game by Dreamweaver Labs. If I play a game, close it, & go to open another, it does not usually work. If it opens, it freezes. Other times, my whole tablet freezes. More often, I have to go to a task mgr., kill all apps, flush the cache, & try again. If that doesn't work, I can keep trying, but usually will have to reboot. The back of the tablet gets kind of hot too which my Samsung never did. I've got a total 38 apps on this PIPO, 17 are mine. My first generation Samsung has 135 apps of total apps. With half the memory of the PIPO, it runs flawlessly.
    OK so, what I want to know is:
    1) Is there anything else, short of popping the tablet open & soldering since I am still under warranty, and PIPO has offered to take it back if I flash it back to their rom, that I can do to try to improve thr WiFi?
    2) What could possibly be causing the freezing problem, especially when I see there is plenty of memory available when I go in to the task manager prg.?
    Thank-you. Any help is appreciated.
    I think you are on the right track. This sounds like a hardware issue....possibly a bad soldering job. I would send it back, since it is still under warranty.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Randy
