What to do before flashing a new firmware
Backup
Originally posted by crshNbrn View PostWhat is the user suppose to do firsdependentre flashing a new firmware to make sure its a fully clean install.
More important though is to back up your original. How is depending on your device. You will have to research it..Good luck.
Read everything you can about your device. AFAIK, no one has developed a non-flickering non-OEM kernel for the J22, for instance. Also, you'll need to know how to get your device into Mask ROM mode.
As mentioned above, back up your ROM before installing a custom ROM. For 3188 devices, see the thread in the Development Area>ROM Hacks and Mods Development, Backing up our RK Device (ROM) with the New RK 2.1 Tool http://www.freaktab.com/showthread.p...ew-RK-2-1-toolMK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
There are currently 1758 users online. 0 members and 1758 guests.
