playback issues
    playback issues
    I have these two big problems with my cs968…
    1. When I am playing movies stored on my desktop pc ,
    through my local wi-fi network (…using my wi-fi rooter and usually using es explorer for accessing the video files stored on my pc,),
    many times the playback of the movie ,stops (mxplayer,bsplayer etc )
    and I am facing the es explorer’s navigation screen. (Except this -pop out- issue ,the movie's playback, is great )
    Some times this happens often ( every 4-5 minutes ) and some times the playback of the movie is great ,with no issues.
    I thought that was a wi-fi problem ,so I connect the tv –box with the rooter with a utp cable, making use of the Ethernet connection.
    The problem remains…
    (the movies playbacks well from my local sd or external sd card )
    2.My biggest problem is that I am having playback video drop-frames (..not very acute but annoying )
    when I enable the rockchip spdif passthrough sound option , to hear the sound through my sound system ,
    ..i have this issue even when the movie is on my local sd card.
    This really makes me angry.
    (… the issue remains with all video players mxplayer ,bsplayer etc )
    I tried all the roms I found here http://www.freaktab.com/showthread.p...01-UGOOS-UG410 with no luck.
    Please help me !!!
    did you try xbmc..
      xbmc works fine , when i am not using spdif passthrough
