I have the kitkat 1.8 riley rom installed on my M6 pro but whenever I run certain apps such as Sky Go Tablet, it says it can not run on rooted devices. This also happened when running stock pipo rom.
I have followed the following instructions, but the same issue occurred with
Sky go stating rooted.
Has anyone got this to work? Do some apps use white lists and if so, could we use build prop to tick apps into thinking the pipo was a mainstream tablet???
1) See that ur tablet/phone is fully rooted
2) Download build prop editor from playstore : https://play.google.com/store/apps/d...ld.prop.editor
3) create backup of original build.prop file that resides in /system (within build prop editor app)
4) search for ro.build.tags in build.prop file
normally U will see that the value is 'test-keys' , change that value into 'release-keys'
5) save build.prop file , quit build prop editor , re-open build prop editor and verify that the changes are really saved.
6) used SU by chainfire to completely remove root
7) goto apps, and STOP the Sky go app, empty cache and delete all settings.
8) open Sky go app and see if it works. If not : verify ro.build.tags in build.prop again or try to reboot tablet. If it still does not work, then this was not the solution for the Sky Go app but only for our local tv player here.
All credits go to writer of this article : http://blog.johanvanbogaert.be/2013/...dersteunt.html and member pipo2000 for pointing me there.
