trying to figure out what I have
My cousin bought this last year and the wifi sucks and it's been sitting around. I think it's a clone but I'm not 100% positive. I'm just wanting to know if there is anyway I can make it better using a custom rom and what rom would actually work. Also would a usb to ethernet adapter work with this unit?
Tags: None
It's obviously a MK809. I have no idea if there are MK809 clones out there. The main reason for crappy wifi is a crappy antenna, so software updates may not help. If you have some experience in this you can try to solder a proper antenna.
EDIT: you can ask about a custom firmware here:
http://www.freaktab.com/forumdisplay...G802-UG007-etc
These devices are very similar to yours.Last edited by phinc; 02 March 2014, 17:15.
Originally posted by phinc View PostIt's obviously a MK809. I have no idea if there are MK809 clones out there. The main reason for crappy wifi is a crappy antenna, so software updates may not help. If you have some experience in this you can try to solder a proper antenna.
There are currently 3819 users online. 0 members and 3819 guests.
