MD5 code :
2) You can use this way which was suggested by Finless to take your own dump (I tried it with my rooted stock FW and have my dump rooted now):
3)For rooting I would recommend you RootGenius. On my opinion it is easiest way to do. You can download it somewhere, it isn't a problem. Do not forget to switch on Connect to PC and USB Debugging in setting menu when you run RootGenius. Of course, rockUSB and ADB drivers must be installed before using this tool.
Good luck!
MD5 code :
Good luck!
Thanks very much for the reply Digger.
I am almost ready to return this and getting an Ouya instead as seems to be better for XBMC (my main reason for buying)
On yours, which image and kernel have you flashed,please? Also does XBMC run flawlessly with 1080p and does Icefilms etc?
Thanks very much for the reply again
You probably know this board has 3188T instead of full clocked 3188. So I could'n reach any positive result with 1080p due to the lower performance.
If you want you can try and check wasser 1.2.4 FW with this kernel http://www.freak-tab.de/wasser/kerne...-nocpulock.img
Sorry friend, I cannot give you any wise advice with XMBC. I don't like it. I always use MX PlayerPro for playing movies online and from my local sources and I have never tried Icefilms because I prefer to have my native language(Russian or Ukrainian) when I watch movies.
