Please Help = My MK809II suddenly stuck
    Hello all,
    I have MK809II with Finless 1.7a installed since 1.7a appeared in 2013.
    All OK since yesterday, when from unknown reasons, the image was freezed.
    I've disconect power cable and reinsert it but on boot seems to be stuck, cannot parse the boot, it stay on boot logo. Tried also the reset button but only obtain the dead android, nothing more.
    How can I enter in recovery mode to can erase all data/factory reset or what else to do to make it work?
    Thank you in advance.
    >>> please help me !!! <<<
      .. not even a small hint for me??? ..
        flash boot with cwm recovery. plug usb on a computer. it will boot on cwm.
        use adb shell on the computer and use e2fsck on partitions.
        if it didnt work, reflash!
          ... thank you .. finally solved, but not with e2fsck, with reflash.
