Beforehand a really BIG BIG THX to
aloksinha2001, linuxium, mmm123
I) Foreword
II) Dualboot Android & Linux
III) First steps at Linux
IV) Backup
V) Android & Multiboot Linux
VI) Different devices / kernels
sudo passwd root [I]<enter>[/I]
sudo passwd linuxium [I]<enter>[/I]
sudo nano /etc/network/interfaces [I]<enter>[/I]
pre-up ifconfig eth0 hw ether [I]e2:38:61:79:76:74[/I]
cd /lib/modules
sudo tar -xzf /home/linuxium/dx05_sd_linux_1.1.0_modules.tgz
ls /dev/sd*
sudo mkdir /mnt/usb-stick
sudo mount -t ext2 /dev/sdb1 /mnt/usb-stick
ls /mnt/usb-stick
sudo tar -xzf /mnt/usb-stick/dx05_sd_linux_1.1.0_modules.tgz
ls -al /lib/modules/3.0.36+/kernel/fs
sudo depmod -a
sudo insmod /lib/modules/3.0.36+/kernel/drivers/net/wireless/rtl8188eu/8188eu.ko
ping -c 5 {another ip at your network}
nslookup www.google.com
ping -c 5 www.google.com
sudo apt-get install openssh-server
sudo apt-get install vsftpd
cd /etc
sudo nano vsftpd.conf
sudo restart vsftpd
sudo apt-get install tightvncserver
vncserver
cat /home/linuxium/.vnc/LINUXIUMONE:1.log
vncserver -kill :1
sudo nano /etc/init.d/vncserver
#!/bin/sh -e ### BEGIN INIT INFO # Provides: vncserver # Required-Start: networking # Default-Start: S # Default-Stop: 0 6 ### END INIT INFO # the user for whom the VNC-Server starts export USER="linuxium" # the Display-Nummer DISPLAY="1" # the color depth (8, 16 or 24) DEPTH="16" # the desired resolution GEOMETRY="1024x768" # the name of the VNC-Desktop NAME="linuxium-VNC" OPTIONS="-name ${NAME} -depth ${DEPTH} -geometry ${GEOMETRY} :${DISPLAY}" . /lib/lsb/init-functions case "$1" in start) log_action_begin_msg "Starting vncserver for user '${USER}' on localhost:${DISPLAY}" su ${USER} -c "/usr/bin/vncserver ${OPTIONS}" ;; stop) log_action_begin_msg "Stoping vncserver for user '${USER}' on localhost:${DISPLAY}" su ${USER} -c "/usr/bin/vncserver -kill :${DISPLAY}" ;; restart) $0 stop $0 start ;; esac exit 0
sudo chmod a+x /etc/init.d/vncserver
sudo update-rc.d vncserver defaults
/etc/init.d/vncserver start
/etc/init.d/vncserver stop
Size Used Avail linuxium-ubuntu1204: 2.5G 1.6G 770M linuxium-lubuntu1304: 2.5G 1.8G 594M linuxium-xubuntu1304: 2.5G 1.9G 462M linuxium-debian7-wheezy: 3.0G 2.7G 127M picuntu-4.5-basicgui: 1.2G 1.1G 42M
sudo resize2fs /dev/[I]{device(-partition-number)}[/I]
sudo resize2fs /dev/sda
sudo apt-get install gparted
sudo fdisk -l /dev/[I]{device}[/I]
sudo fdisk -l /dev/mmcblk0
Device Boot Start End Blocks Id System /dev/mmcblk0p1 63 12370049 6184993+ 83 Linux /dev/mmcblk0p2 12370050 24740099 6185025 83 Linux /dev/mmcblk0p3 24740100 37110149 6185025 83 Linux /dev/mmcblk0p4 37110150 61850249 12370050 5 Extended /dev/mmcblk0p5 37110213 49480199 6184993+ 83 Linux /dev/mmcblk0p6 49480263 61850249 6184993+ 83 Linux
sudo dumpe2fs -h /dev/[I]{[/I][I]device(-partition-number)}[/I]
sudo dumpe2fs -h /dev/mmcblk0p1
Filesystem volume name: linuxroot Last mounted on: / Filesystem UUID: edda5ddd-7965-4b24-89d2-2663c305a4e6 : Filesystem OS type: Linux Inode count: 163840 Block count: 655360 Reserved block count: 32768 Free blocks: 229691 :
sudo dd bs=4M if=[I]{image-name} [/I]of=/dev/[I]{device(-partition-number)}[/I]
sudo tune2fs -L [I]{device(-partition)-label-name}[/I] /dev/[I]{device(-partition-number)}[/I]
sudo dd bs=4M if=linuxium-ubuntu1204-desktop-rfs-BASIS.img of=/dev/mmcblk0p1 sudo tune2fs -L linuxroot /dev/mmcblk0p1
sudo dd bs=4M if=linuxium-ubuntu1304-lubuntu-desktop-rfs.img of=/dev/mmcblk0p2 sudo tune2fs -L lubuntu /dev/mmcblk0p2
sudo dd bs=4M if=linuxium-ubuntu1304-xubuntu-desktop-rfs.img of=/dev/mmcblk0p3 sudo tune2fs -L xubuntu /dev/mmcblk0p3
sudo dd bs=4M if=linuxium-debian7-wheezy-desktop-rfs.img of=/dev/mmcblk0p5 sudo tune2fs -L wheezy /dev/mmcblk0p5
sudo dd bs=4M if=picuntu-4.5-basicgui-nand_system.img of=/dev/mmcblk0p6 sudo tune2fs -L picuntu /dev/mmcblk0p6
mkdir ~/img [I]<enter>[/I] mkdir ~/SD_part [I]<enter>[/I]
sudo mount -o loop [I]{image-name}[/I] ~/img [I]<enter>[/I] sudo mount -t ext4 /dev/[I]{device-partition-number}[/I] ~/SD_part [I]<enter>[/I]
sudo cp -r -a ~/img/* ~/SD_part
sudo umount ~/SD_part [I]<enter>[/I] sudo umount ~/img [I]<enter>[/I] sudo tune2fs -L [I]{device-partition-label-name}[/I] /dev/[I]{device-partition-number} <enter>[/I]
mkdir ~/img mkdir ~/SD_part sudo mount -o loop linuxium-ubuntu1204-desktop-rfs-BASIS.img ~/img sudo mount -t ext4 /dev/mmcblk0p1 ~/SD_part sudo cp -r -a ~/img/* ~/SD_part sudo umount ~/SD_part sudo umount ~/img sudo tune2fs -L linuxroot /dev/mmcblk0p1
sudo mkdir ~/SD_part
sudo mount -t ext4 /dev/[I]{device(-partition-number)}[/I] ~/SD_part
cp dx05_sd_linux_1.1.0_modules.tgz ~/SD_part/home/linuxium
cp dx05_sd_linux_1.1.0_modules.tgz ~/SD_part/home/picuntu
################################### ## ## ## 1. mmcblk0p1 linuxroot ## ## 2. mmcblk0p2 lubuntu ## ## 3. mmcblk0p3 xubuntu ## ## 4. mmcblk0p5 wheezy ## ## 5. mmcblk0p6 picuntu ## ## ## ################################### Please select a partition [1..5]:
sudo chmod a+x switch_rfs
sudo ./switch_rfs
sudo dd bs=4M if=/dev/mmcblk0p[I]{partition-number}[/I] of=[I]{wherever-you-want}[/I]
CONFIG_CMDLINE_FROM_BOOTLOADER=y # CONFIG_CMDLINE_FORCE is not set
"root=LABEL=linuxroot"
# CONFIG_CMDLINE_FROM_BOOTLOADER is not set CONFIG_CMDLINE_FORCE=y CONFIG_CMDLINE=xxxxxxxxxxxxxxxxxx
CONFIG_CMDLINE="initrd=0x62000000,0x00800000 root=LABEL=linuxroot init=/sbin/init"
- General - Extensions -> Install the 'VM VirtualBox Extension Pack'
Name: {what ever you want} Type: Linux Version: Ubuntu (64 bit) -> Next Memory Size: >=1024 MB -> Next Hard Drive: 'Create a virtual hard drive now' [Create] Hard drive file type: 'VDI (VirtualBox Disk Image)' Storage on physical hard drive: 'Dynamically allocated' File location and size: >= 10GB
- General -> Advanced - Share Clipboard: Bidirectional - Drag'n'Drop: Bidirectional - System -> Processor - >= 2 - Display -> Video - Video Memory = 128 MB - Enable 3D Acceleration - Storage -> CD -> via the symbol select the 'Ubuntu.iso' file you have downloaded - USB -> Enable USB 2.0 - Shared Folder -> 'Machine Folders' -> [+] [U][B]DO NOT CHECK[/B][/U] 'Auto-Mount' !!!
uname -a
sudo apt-get install linux-headers-3.5.0-27-generic
sudo nano /etc/fstab
{your-share-name} /home/{your-user-name}/{your-share-name} vboxsf defaults 0 0
Transfer /home/ich/Transfer vboxsf defaults 0 0
sudo reboot
sudo apt-get install git-core flex bison build-essential gcc-arm-linux-gnueabihf libncurses5-dev zlib1g-dev lib32z1 lib32ncurses5 sharutils lzop
CONFIG_INITRAMFS_SOURCE="{path to the cpio}"
CONFIG_INITRAMFS_SOURCE=""
sudo apt-get update sudo apt-get upgrade sudo apt-get install git-core flex bison build-essential gcc-arm-linux-gnueabihf libncurses5-dev zlib1g-dev lib32z1 lib32ncurses5 sharutils lzop mkdir RK3188 cd RK3188 mkdir Tools mkdir SRC cd SRC mkdir aloksinha cd aloksinha git clone git://github.com/aloksinha2001/Linux3188 # 167.42 MB cd Linux3188 mv .config .config_aloksinha cp ~/Transfer/mmm123_config_1.1.1/config.1.1.1_recovery .config cd ~/RK3188/SRC/ mkdir mmm123_initramfs cd mmm123_initramfs cp ~/Transfer/mmm123_dx05_boot_from_sd_recovery_1.1.1/dx05_sd_linux_1.1.1_recovery.img recovery.img cd ~/RK3188/Tools git clone git://github.com/olegk0/tools mv tools olegk0 mkdir Kuisma cd Kuisma cp ~/Transfer/unmkbootimg.gz unmkbootimg.gz gunzip unmkbootimg.gz cd ~/RK3188/SRC/mmm123_initramfs ~/RK3188/Tools/Kuisma/unmkbootimg recovery.img > unmkbootimg_output.txt cat unmkbootimg_output.txt ls -al cd ~/RK3188/SRC/aloksinha/Linux3188 make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j2 ls -al arch/arm/boot/ ls -al ~/RK3188/SRC/mmm123_initramfs/ mkdir ~/RK3188/Kernel mkdir ~/RK3188/Kernel/mmm123 cd ~/RK3188/Kernel/mmm123 mv ~/RK3188/SRC/aloksinha/Linux3188/arch/arm/boot/Image Image mv ~/RK3188/SRC/aloksinha/Linux3188/arch/arm/boot/zImage zImage ~/RK3188/Tools/olegk0/mkbootimg --kernel Image --ramdisk ~/RK3188/SRC/mmm123_initramfs/initramfs.cpio.gz --pagesize 16384 --ramdiskaddr 62000000 -o recovery.img ls -al cp recovery.img ~/Transfer/recovery_mmm123.img
cd RK3188 cd Tools git clone https://github.com/phjanderson/marvin # 76.34 kB cd ../SRC mkdir phjanderson cd phjanderson git clone https://github.com/phjanderson/Linux3188 # Merge of https://github.com/aloksinha2001/Linux3188 # 167.50 MB .......
There are currently 2559 users online. 0 members and 2559 guests.
