Tronsmart X5II/Bee-link X5II - HELP!!!
    Originally posted by Luckito View Post
    Unfortunately not got any help or solution, it is a pity that no developer or someone who knows a bit more than we have been interested in helping us
    If you give me the kernel.img and boot.img for your device I will patch it for you to get rid of the video problem, It will only take me a few minutes
      Hi! thank you, how can I remove the kernel.img and boot.img?
        just take it from your ROM that you have flashed to your device that works. Or give me a link to a ROM that works for your device
          Sorry, I have the firmware but do not know take the kernel.img,this the link of firmware http://www.mediafire.com/download/xc...j2105_0317.img
          this will fix the crashes when I play videos? or is necessary to overlock?
            it will stop the video from stuttering, that is the common problem with the processor it will not stop the box from crashing though. I am downloading the ROM now, it is up to you, you have got three options , just have the video fix or overclock the CPU or both
              most of my movies are in 1080p and high bitrates, which causes the lags, I would greatly appreciate it if you put both modules for me, video fix and overlock processor, but if it is too much work for you, only the video fix its a wonderful help, thanks again!
                I have just finished downloading the ROM, it does not have a separate kernel.img it is inside the boot.img it needs separating before I can do anything with it. It is getting late in the uk now so it will be tomorrow before I can do it but it should not be a problem, although you should be aware that rk3188 struggles with high bitrate 1080p it will be better, but not perfect
                  I already suspected, and a weak processor means, then I hope your help, I will be very grateful, good night!
                    Here is the ROM, it has the video fix and it is overclock to 1.7GHZ CPU AND RAM @ 667 .please use this link for instructions on how to use RKAndroidTool to flash the ROM http://wiki.radxa.com/Rock/flash_the_image
                    link to the ROM https://www.dropbox.com/s/07qe6un1o7...5_0317.7z?dl=0
                      hi! thank you dear friend, I will test the rom, night and update the post with my impressions, I'm sure many people will enjoy its magnificent job, thank you very much, God bless you.
                        What about version 3.0
                        Could you if its not much of a bother please apply the same patch to the v3.0 firmware as you did on the v2.0 firmware? The link to the X5II v3.0 firmware is http://www.mediafire.com/download/jf...j2301_0317.img
                          Thanks for this fix sam321.
                          I got jesurun mx that is x5ii clone and this firmware works with that device. I have been searching working rom for a long time.
                          Just installed this rom and it's working better than any other firmware. just trying 720p video using xbmc and its pretty good. Something happened and video turned to artifacts after opening xbmc menu while watching and i was unable to continue watching movie. xbmc needed to restart. I am watching video from usb stick. Need to test videos over ethernet and wlan another day.
                          Youtube works and hd video was smooth.
                          Rom has root access.
                            Yes sure, sorry it took a while to get back to you but I have been busy. I will do it tomorrow if you still want it
                              seems not working
                              Hi, i tried your rom patched, it seems that version uses cpuset which suppresses frequencies higher than 1.4GHz
                              At the result, there is only 1.2GHz
                              edit:
                              So, I opened up my box and I found that the chip was a rk3188t and fw v2, this explains a lot, damn I'm a bit sad..
                                Hi, sorry i didn't answer, i've been abroad on bussiness in russia for a month now, just got back lastnight the answer is yes, please if it is not too much of a bother i would really appreciate if you could apply the patch on the v3 firmware. Also is there a detailed walkthrough or tutorial about how the patches are applied that you can recommend? prefferebly one for windows users and not linux since my linux skills are basically below a noob's
