What is this K-R48 RK 3188 running 1.8Ghz for sale at Newegg for $112?
    http://www.newegg.com/Product/Produc...9SIA35218K1471 $112 K-R48 RK3188 Quad Core ARM Cortex A9 1.8GHZ Mini TV BOX 2G/8G BT 2.0MP camera and Mic Double External Wifi Antenna - Black RK3188 Quad Core ARM Cortex A9 1.8GHZ; Mail-400 MP4 GPU
    Android4.2.1 and Miracast(Wifi-display)
    2GB DDR3 + 8GB NAND Flash; Double External Wifi Antenna
    Build-in 2.0M wide angle camera
    Support RJ45/Bluetooth
    Specification:
    CPU: 28nm Quad core ARM Cortex A9 1.8GHZ (RK3188)
    GPU: Mail-400 MP4
    RAM: 2GB DDR3
    Memory size: 8GB NAND Flash Android OS: Android4.2.1 and Miracast(Wifi-display)
    IPU: OPEN GL ES2.0 and 1.1, Open VG1.1,special 2D hardware Engine
    Camere: 2.0M wide angle camera inside
    Interface:
    Video Output HDMI v1.4 digital HD interface (max video output resolution 1080p@60Hz)
    Audio Output HDMI v1.4 digital HD interface
    LAN RJ45(10/100Mbps)
    CARD SD card reader,max capacity 32GB
    WIFI: 802.11B/G/N Wifi.Bluetooth 2.1,Dual External Antenna
    USB: USB 2.0 X 4, support Smartphone Charge and HDD W/O Power
    Power supply: 5V 3A
    IR: IR X1
    Media format:
    Video: M-JPEG,MPEG-4,H.264,VC-1,DivX, Xvid, RealVideo,VP8,MVC
    Audio: RM/RMVB, MPEG, MKV, AVI, MP4,MOV,FLV, H.263,H.264,VC-1,DivX, Xvid, TS
    Photo: JPEG/BMP/PNG
    Unit Size: 250*40*60mm,Net Weight: 200g; Color:Black
    Package Includes:
    1*hdmi cable
    1*av cable
    1*power charger
    1*IR Remote controller
    1*user manual
    This seems to be a pretty high end specs, same class as the cs968/cr11s but a bit more. The only thing you should think about is lack custom rom support for now, so you may stuck with stock rom for a while...If you are ok with stock rom then it's a good buy.
      "Sold & Shipped By Geekbuying"
      Check out Geekbuying's own listing for this item. They've updated the product description to note that it has an RK3188T processor. Newegg's description is out of date, though it is possible that there is still Non-T stock on the shelf and that you'd get it. Probably won't run 1.8 though, so not worth this price, IMHO. Maybe half that, if you know what you're getting into.
