Pipo m6 pro 3g a bit laggy?
    Hi all,
    I am having a bit laggy and frustrating pipo m6. Its with the latest OTA firmware. I've just installed cpuspy and noticed that's its using constantly only very low CPU frequencies and also it never goes to deep sleep even though that its idle during the whole working day.
    Is this usual or is it a sign of a problem?
    Thanks in advance!
    Sent from my M6pro using Tapatalk
    Jelly bean CPU governor tend to use low freq a lot. Install a kitkat version (stock or RileyRom), you will immediately see a great performance improvement and longer battery duration.
    Deep sleep is disabled on stock rom.
    RileyRom have the correct libril file that allow deep sleep to work.
      you could root it and delete some useless applications to make it faster.
      Coolicool - Located in China and a trusted seller on Freaktab. We are selling loads of Android TV Sticks, Tablets, Smartphones and consuming electronic merchandises to all over the world. We have local Warehouse in Europe that our customers can get what they want in 72 hours(2-5 Days Delivery&No tariff).
      Lowest Price Guarantee
      Easter Special Offer!
      Link: http://bit.ly/2Iy2Av4
        You're right, but I think that the best performance boost could be achieved only with kitkat ROMs
          Hi
          I did flashed to rileyrom 1.8 kit kat and there's a huge performance and battery life improvement. I am very satisfied. Only bad thing is that hay day farm game is unplayable because of a screen freezing issue. Screen is unfreezed only when theres an OSD overlay of some sort for example when you press volume buttons. It seems as a general issue since I've seen many complaints from the same. Any ideas?
          Thanks again the ROM is perfect!
          Sent from my C6603 using Tapatalk
