Skyworth SkyPad S73 stock rom Firmware needed [help]
    Hello,
    Can somebody help me i accidentally click the erased button IDB nand flash, i forgot to backup the recovery.
    Please share stock rom firmware and instruction how to recover my tablet. thanks in advance.
    SKYWORTH S73 SPECs:
    RK3066 Processor CORTEX A9 1.6Ghz
    Android 4.1.1 Jelly Bean
    RAM 1 GB
    Internal Memory 4GB (supports up to 32GB)
    Screen Size 7" Digital Resolution 1024×600 Capacitive-Touch (COB) Multi-Touch
    WiFi 802.11 b/g/n
    Bluetooth 2.1
    Dual Camera
    Battery 2800mAh
    Features
    Sharp and clear
    Dual camera
    Wireless connection
    File Sharing
    Android technology
    Pure digital entertainment
    More storage for you, micro SD card up to 32GB capacity.
    My Problem Solved.
      s73
      Originally posted by dareangel11 View Post
      My Problem Solved.
      where did you get the s73 firmware?pls help.
        I actually managed to download one by one by DUMP the entire NAND memory. 3 weeks of learning.
        CWM and TRWP are not working with my S73.
        If you are using Terminal to download the firmware, it was not working because it was incomplete. when you flash the unit will not boot and will brick.
        Also rooted by binary #18.
        I hope this short information will help you.
          My Skyworth Skypad S73 Backup Rom
          Build into a single firmware image by: Dareangel11
          Email: [email protected]
          Download
          Not for sale, Password protected..
          Thanks to Finless Bob.
          www.freaktab.com
            good day
            Download
            www.freaktab.com
            ei boss, i already emailed you, just hoping if you could give me the password for this file, my skyworth went to bootloop... please help, thanks in advance...
              Ok, password was sent to you thru email.
                thank you, i will check my email...
                edit: got it thank you, have you try any cwm on your skyworth??
                is this one not working http://www.freaktab.com/showthread.p...for-Rockchip-s
                  yes. still incompatible
                    sir
                    sir i also need your stock ROM. my skypad tablet brick and need to flash. i need your help. i already email you.if ever can i know your password?. thanyou in advance.
                      Download
                      www.freaktab.com
                        check your email sir.
                          Thank you so much
                          Flashing mode. thankyou sir.
                            Can i ask for the password sir? i have here skypad S73 boot loop also. tanx in advance.. my email is [email protected]
                              Please send a request email to my yahoo. I will reply there and kindly give a positive fedback.
                              Thanks to this web site.
