M6Pro + 64GB SDXC ?
    M6Pro + 64GB SDXC ?
    According the tech. spec. the M6Pro only supports 32GB microSD cards. However, I have seen posts, where someone told he is using a 64GB (SDXC) card.
    Can someone confirm this is possible, and what is needed for this to work?
    Is it possible to insatall some 3rd party exFAT drivers to use the 64GB of storage like the
    I’m using sandisk 64g memory card, But some app can not read file on exfat file system, NTFS is recommand.
      Thanks for response.
      It is good to know it works. Unfortunatelly NTFS file system is not very suitable for flash memories, due it's journalling feature. But a lot of people are using it at their home computers with SSD, so what :-)
      AFAIK Raileys ROMs do support NTFS file system, but I don't know if the mode is RO or RW.
