Bricked device?
Bricked device?
Hi need help.Have an RK3188 Android box.It seems i flashed it with a dodgy firmware.Now it wont do anything for me.All i get now is the blue light on top.The RK batch tool detects it but when i go to flash it,i get the message prepare idb fail?Is there anyway of getting this box to booth again?Thanks for any help.Oh and this is a ppic of boardTags: None
Originally posted by exglynco View PostTry putting it in Mask ROM by shorting NAND pins 8-9 while connecting the device's USB-OTG port to your PC.
Sent from my Nexus 7 using Tapatalk
NAND chip is the big one with multiple pins located below the RK3188-T CPU. Pin 1 is in the lower right corner. Count from there to 8-9. The
spec sheets for different NANDs differ (look yours up) . You want to short CE and RE
Sent from my Nexus 7 using TapatalkMK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
Originally posted by exglynco View PostNAND chip is the big one with multiple pins located below the RK3188-T CPU. Pin 1 is in the lower right corner. Count from there to 8-9. The
Originally posted by bozharry View PostWhy the dreaded T version chip?Is it crap?
There are currently 2861 users online. 1 members and 2860 guests.
