X7 with 1080p and DTS
    Hello,
    I just received my new X7 and it is awesome.
    I have few questions... I tries to find the info on my own here and on other sites but there are many guides and most of the seem outdated.
    I want to view 1080p movies (my Samsung TV supports 100HZ) using XBMC. I also have a nice sound bar which it will be very disappointing if I could not use, so I would like to have DTS support (I read this is kind of a problem).
    Also, I would like to stream content using Netflix (I understand Netflix annoyingly does not support HD on android)
    And of-course YouTube and internet browsing.
    How do I assemble all that?
    Is there a nice ROM which can help me?
    Please share your experience with me.
    regards,
    Id
    Originally posted by ididid View Post
    Hello,
    regards,
    Id
    Will, i think most of the Roms in x7 sellection can handle that! :-)
    2 i think you should try, Quickshot v2 and HardwareGuru 04.
    Was using Quickshot for long time, and that Was great ! :-)
    Right now i'm on Hardware gurus 04,that handles live streaming better, but has no root std..
    Try Them out and see what you like most! :-)
      Thanks... Looks great. I think I'll go for the hardware guru.
      What about Netflix? Does it support HD even though it is not runnig on abdroid 4.3?
        Nope, no HD for us.. I dont think any of these Android sticks has Netflix in HD, i did read some thing about that the manufracture has so make a drm partition that Netflix can see before HD will be there, and ofc android 4.3+ or something like that, dont remember it correct more.. But Netflix is watchable :-) Like a dvd..
          That's disappointing. Especially because chromecast has super Hd netflix streaming.
          Thanks.
            You can try
              Yes I saw this posts including xda's Netflix app. But at the end you need android 4.3 or later to support HD content.
              What about the 4.4 rom?
                After some more digging...
                1. What about the kit-kat rom?
                  Will it do all the stuff I need? The 1080p seems a beat poor with 24HZ only.
                2. Also, Let's say I go with HardwareGuru 4 rom: I noticed it comes with minix xbmc beta. Isn't the beyond xbmc version better? In the HardwareGuru post, the creator emphasized that he had modified xbmc stuff to play 1080p smoothly. I am a beat confused.
                Thanks.
                Regards.
                  1080p with 50/60hz run just fine in Wassers rom.
                    HardwareGuru 4c beta version runs best on my X7.
                    1080p 50/60hz is not so smooth, but 1080p @ 24hz + DTS sound works so smoothly!!! I tried other roms but hardwareguru 4c is for me best for watching videos on xbmc
                    iPhone5 using Tapatalk
                      Ok, I think i'll go with hardwareguru 4 rom. but i have to ask: did you mariozo tried the Kitkat rom?
                        No, i have not try.. I want stable rom, with 1080p + DTS spdif passthrough. I think that dts dont work on kitkat and is not stable...
                          Thanks... I thought so.
                            Im using 4c rom!!
                              Im using 4c rom!!
                              This one?
