Not recognised by PC
I recently bought a iconBIT Toucan G4 TV Stick. Basically it's a RK3188 with an AP6330 Wifi/Bluetooth module. I wanted to set it so that it could use the external SD card for Apps or XBMC cache, but it does not show up when I connect it to my windows 7 PC. There is no reset switch on the mainboard (the location where this would be installed normally just has the two holes and solder points either side). Could this be the problem, as in I would need to "reset" it to show it to windows as a new device ? I am new to all this with Android, but I have no problem with messing with the hardware or software. Just need to know if I am looking in the right direction. For info it isn't already rooted. Thanks for any advice.Tags: None
There are currently 1995 users online. 2 members and 1993 guests.
