mk809 rom or firmware?? help
Hi, i recently bought a mk809 (k9) tryed to upgrade it but wifi does not work after searching this fourm i have read it must of..been the wrong rom for my device can some help/tell me were i can get the right rom from please i would apprecate your time to reply thank youTags: None
MK809 / UG802-V2 , with RK3066 and RTL8188EUS
Hello all!
I would like to ask you to recommend good ROMs for my litle TV BOX.
This device is should be an UG802, but when I tried to use ug802_finless_18_beta, it turned out it is one of the "new" or "clone" UG802. One UG802-V2 with RTL8188EUS. Galery. I reinstalled the original ROM, but it is lame
After reading and searching alot, I found this hardver mod. I made it, and now WiFi is working fine.
I downloaded one Android 4.2.2 ROM for one MK809 , and it is working fine now, but I would like to try out other ROMs.
What should I download? I'm looking for NTFS support, surround audio if possible (some kind of HDMI SPDIF pass through, or USB sound card support), USB camera support, USB mic support, and maybe a little overclock.
Please help me if you can! Thanks!Last edited by kisist1; 09 September 2014, 22:09.
It seems, MK802III ROM is also working with this WiFi mod. I thied MK802III_131108 ROM.
I guess, it has the same WiFi chip, RTL8188EUS.
And I see this ROM also support SPDIF 5.1 output, and Micropone. I tested with AC3 5.1, and it worked! I will test the Mic and the webcam, if I will have an USB hub
Other question:
Would I brick my RK3066 device if I would flash one RK3188 ROM?Last edited by kisist1; 09 September 2014, 23:26.
There are currently 2574 users online. 0 members and 2574 guests.
