720P kernels with ASIX ax88179_178a working driver for Finless KitKat 2.0 ROM
    After many adventures I can present You my own kernels for Android KitKat with real ASIX AX88179_178a wonderful USB GB LAN adapters!
    Here: https://drive.google.com/folderview?...kE&usp=sharing
    In this repository You can find for this moment only SD kernels for RK3188 tv sticks with RTL8188eu/6210/6330 wifi but... If You have asix You will not use wifi anymore
    For developers I add driver with Makefile and Kconfig entries setup guide! Regards and have fun!
    Hi thank you for this i will try it when i will flash kit kat on my MK908II. But i want to ask if it easy for you to include this feature in 4.2.2 kernel so i can test it with Finless 1.5a.
      At this moment answer is no, something in usb_otg driver is messed up in JB.
        Superb work Yerzu. Thanks for this. I'll add this modded driver into into my builds if you are happy?
        Donate to Finless
          Sure and thanks again for help with KK!
            and you can build a kernel for ar6210 88772b?
              All my kernels support that ASIX chipset and, because Yerzu has used my .config, so do his.
              Donate to Finless
                Yes of course. Are included, but If You not need 88179 or 88178a driver You should use one of d33 kernels because are very universal f.e. has 1080p resolution and box support - mine probably works only on sticks.
                  [QUOTE = yerzu; 155483] Да, конечно. Включены, но если вы не нуждаетесь 88179 или 88178a драйвер Вы должны использовать один из D33 ядер потому очень универсальный Fe имеет разрешение 1080p и коробки поддержку - мой, вероятно, работает только на палках [/ QUOTE].
                  I USE THE CORE OF A 33, BUT it does not support LAN 88772B, no I can not help it, unfortunately I YOURSELF IN THIS LITTLE UNDERSTAND
                    Probably You use some page translator (google translator) and is hard to understand You... and funny because that what You quote is in Russian and in this case You quoting my words which I wrote in english and I was thinking that I'm the worst english writer.. till now
                    I try to answer (but I don't sure that I understand Your words):
                    Drivers are build in kernel (sometimes can be added as modules) and if You use kernel with driver support that device should work (but is possible that driver is messed up like stock from ASIX for 88179). Please run terminal emulator on Your stick/box android and do:
                    1. write "su" enter
                    2. write "dmesg > /sdcard/dmesg.txt" enter
                    3. attach here file from /sdcard/dmesg.txt on Your stick/box android
                      dmesg-1.txt Я сделал не так ли?
                        No usb Device detected. OTG port initialises and usb mouse detected. That's it.
                        My tv box has AX88760 device on board which uses same driver. Four port hub detected and ASIX chip detected and Ethernet support provided.
                        Using my ipad so apols for any stupid ios spelling 'corrections'
                        Donate to Finless
                          See ASIX website -> http://www.asix.com.tw/download.php?sub=driverdetail&PItemID=103
                          The integrated Ethernet Controller of AX88760 is fully compatible with ASIX's AX88772A USB2.0 to 10/100 Fast Ethernet Controller, therefore AX88772A driver can bring up AX88760 Ethernet controller function without any modification
                          You have this device? -> http://www.amazon.com/Tronsmart-Mk90.../dp/B00EO0MKMI
                          Which has 1 x microUSB and 1 x standard usb ports connected to USB Host on RK3188 and 1 x microUSB connected to USB OTG
                          Donate to Finless
                            : Лицо
                              [ATTACH] 5658 [/ ATTACH]: WTF
