Manufacturer Of CS968 REFUSE To Make 1080p ROM, (CR11S CloudnetGo Makes 1080p ROM), See 720p To 1080p Instructions
    #1080P/4k READY CR11S Made By CloudnetGo In The Above Photo ...!
    CR11S/Neo X7 Android TV Boxes Are The Only 1080p Android TV Boxes With 1080p Screen Resolution Direct From The Factory
    (See Simple Easy Instructions Below On How To Turn A Rooted CS968 720p Android TV Box Screen Resolution To 1080p)
    I'm only recommending purchasing the 1080p CR11S 4.2 made by CloudnerGo and the Minix Neo X7 4.2 Android TV boxes ...
    CS968 Android TV boxes have to many different wifi modules and the manfacturer refuse to build a 1080p ROM build for all wifi module boards ...
    If you desire to purchase a 1080p CS11R, then go HERE http://www.aliexpress.com/item/2013-hot-selling-Cloudnetgo-CR11S-2G-RAM-8G-Rom-RK3188-Quad-core-1-8G-android4-2/1424683447.html ...
    You can purchase the 1080p Neo X7 HERE http://www.aliexpress.com/item/SuperFree-RC12-MINIX-NEO-X7-Quad-Core-TV-Set-Top-Box-RK3188-Cortex-A9-CPU-2GB/1669603386.html ....
    HOW TO TURN A 720P ROOTED CS968 SCREEN RESOLUTION TO 1080p (Simple Easy)
    1./ Go to Settings on your CS968> Screen> HDMI Mode> Set to 1920x1080p-60 ...
    2./ Install this "Terminal Emulator" found HERE https://play.google.com/store/apps/details?id=jackpal.androidterm to your 720p Android TV box ... Go the Settings on the "Terminal Emulator"> Preferences> Text and set the "Front size" to 24PT, back out to your "Terminal Window" ...
    3./ Run This Command Via The "Terminal Emulator" (Cosmonaut CS968 720p To 1080p Screen Resolution Hack) ...
    su
    am display-size 1080x1920
    am display-density 240
    4./ Reboot your CS968 manually, PLEASE NOTE: Your BOOT SCREEN maybe disconfigured slightly, it's still 720p, but your CS968 regular TV viewing screen will be 1080p resolution ..
    5./ Verify screen change with An TuTu ...
    6./ Enjoy
    The Latest NEW Android TV Apps Can Be Found HERE (Under "Android TV Apps And ChromeCast", Left Column) https://plus.google.com/communities/...artnerid=gplp0 ....
    This works nicely!! great information, good job pal!
      Your Android TV Box Can Now Access Over 7,000 Channels
      Thanks a ton and a truck load ...
      WatzON TV Brings A NEW DIMENSION TO ANDROID TV 4.2 QUAD CORE BOXES, Plus Over 7000 NEW Channels To Google ChromeCast
      (Cable TV And Satellite TV Cannot Match This)
      Download HERE
      https://play.google.com/store/apps/details?id=com.watzontv.watzontv ....
      *PLEASE NOTE: First Turn ON WiFi, Register And Sign In, That's It ....
      Get more details HERE https://plus.google.com/communities/...artnerid=gplp0 ...
        Tech1, if I want to go back to orginal 720 from:
        what they should be?
          just replace with "am display-size 720x1280" without quotations marks .....
            Can this trick work on other devices too? or is it only for CS968?
              Tricks are for kids, this works, but I have not tested this procedure on other devices ...
                Works on Tronsmart A928, but a bit tricky to go back to 720p :-)
                BTW going back to 720p is 720x1280 and not 720x1024 like you said before :-)
                  Ok! Thanks for the correction, enjoy ...!
                    I tried to go back to 720P on my CS968 by using 720x1280 as instructed but now my screen is not normal and the apps button is on the right part of my screen. Any suggestions? I went back to the 1080x1920 in the meantime. I'm not sure if it was a side effect but once I went to 1080p I was noticing Lag with some games.
                      Just reinstall your 720p ROM build, this will fix your issues ...
                        su
                        6./ Enjoy
                        Very good Tech1 just like the PM i send you.I think its better to run the command without the SU first,so the change will keep untill the next reboot.What about the camera in Skype? Videocall? Can you take a Screenshot?
                          Skype and Hangouts works via the CS968/CR11S via 1080p video with my Android TV boxes ...!
                            To revert back to 720 do the followingdefinitely will work)
                            su
                            am display-density 160
                            Then you must reboot your device to take affect!!!
                            OR try this (I haven't try yet, but I think It should work the same):
                            su
                            am display-size reset
                            am display-density reset
                            Then reboot the device!!
                              su
                              su
                              You are correct with the 160 density, my error when I said 240 dpi, thanks for the corrections, sweet ...
