This is a RK3188 quad core with 8" model 80b is there any rom that i can apply to it.
Arnova 80b
Abdul_pt
Homem se és tuga percebes.
Dá-me um passos e eu vou lá.
Hey Abdul_pt give me some more info to follow and i will achive the objective.
Originally posted by abdul_pt View PostADB shell should be root.
You could flash a custom recovery, and after a root zip.I help with 4GD663269M466950W
And you ????
My devices:
Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
Tronsmart Prometheus won on CNX just now....
Obrigado amigo este fim de semana já testo.
I'm going to try this on the weekend. Btw this tab i own is a Qilive 8qc wich is a archos 80b rebranded i do have archos rom and tried to burn it using it like an update.zip inside root diretory but no deal.
Is it possible to do anything more, or it's more safe just to do a rom dump from the tab?
Um abraço,I help with 4GD663269M466950W
And you ????
My devices:
Originally posted by billgatos View PostObrigado amigo este fim de semana já testo.
Um abraço,
The recovery sounds good and i was already thinking on that or even cmwn .
The root idea is for taking off all the garbage inside the tab and even worse is full of sheety publicity.
That's the reason for root and even change something on the freqsI help with 4GD663269M466950W
And you ????
My devices:
I have root access now
I managed to have access root using vroot i know it's a chinese crap but it worked.
Also to get this qilive 8qc tablet in flash mode i only have to push volume+ button when powering up.
Now i'm getting it's rom using Finless tuto on http://www.freaktab.com/showthread.p...ew-RK-2-1-tool
and Domrad on http://www.freaktab.com/showthread.p...sing-ADB-guide
Abdul_PT i'm gona need your help to clean up this qilive rom if possibleI help with 4GD663269M466950W
And you ????
My devices:
Originally posted by abdul_pt View PostUpload it, mate.
Tapatalked
IT has two dirs one is Finless way other is ADB way wich i believe isn't not that good.
The upload is at 26% i only have 1018 Kbps of up speed
tomoroow we'll talk if possible to you
skype billgatosI help with 4GD663269M466950W
And you ????
My devices:
There are currently 2839 users online. 0 members and 2839 guests.
