Custom Rom to Disable Android Mouse Cursor?? Possible?
    I am using a airmouse a with android/xbmc on a K-R42 and its is annoying on the screen when in XBMC. Is there anyway someone can make a ROM to disable the mouse cursor completely?
    I use a Logitech K400. The mouse disappears when it's not active for a couple seconds. Isn't there a enable/disable mouse on these types of remotes?
      Yes there is but when you disable it, then don't touch any buttons for 10-30 seconds and then touch a button again it reenables the mouse automatically.
      This might be a crappy design of the mouse, but if that is the case I still need to figure out how to completely disable the cursor.
        Nobody can help?
          Nobody can help?
          Hi Cee604,
          I have a similar problem with a gyroscopic mouse I recently bought, and found this potential solution, which I'm going to try tonight
          Add the following to a mouse.xml file in xbmc\userdata\keymaps\mouse.xml
          <keymap>
          <global>
          <mouse>
          <mousemove>noop</mousemove>
          </mouse>
          </global>
          </keymap>
