For best quality live streaming (sports, tv)
    Install the Sopcast application and the Torrent stream controller application (this is for ace stream engine)
    For media player ofcourse the mx player.
    Go with your browser to this link: www.wiziwig.tv/index.php?part=sports and watch your favorite sport live with top quality (select the sopcast or ace stream links)
    Install P2P streams addon (it automatically downloads sop and ace apk to run with XBMC) and/or Livestreams Mod Addon in XBMC, Fightnight repo - Working great with Wiziwig, Arenavision, Livefootballol, Livesoccer, Sopcast.ucz and all Russian/Romanian Torrents channels/lists. Also Portuguese an Spanish xml Lists available, and u can set up your own xml lists, like the VCX7 list usually it's daily updated.
    PD: these addons runnin on Beyond XBMC, of course!!!
      thanks for this information.
        U're welcome
        You can find some wiki on how to install it correctly... Not a big deal though!
        You'll need to run Acestream before XBMC ( I recomend this settings: VOD, 10sec. - Live buffer, 30 sec - Max dl: 300 - Max up: 100, also open port on router, and clean cache )....
        With sopcast you'll need to set permisions on sopcast client file.
        With both ace and sop you just need to set it up once...
          p2p-streams repository
          Hi all,
          Please can you help? I am trying to get the above to work so i can use sopcast and acestream but it will not enabled. Please please help. :-)
            Originally posted by r3ed View Post
            Hi all,
            What do you mean "it will not enabled". What exactly have you done.
              Can you tell me please where i can get this VCX7 list?
                p2p streaming
                Sorry and4468, I only gave you half the information. Right I added fright night to my xbmc and the tried to enable p2p streaming add-on but it would not load into the add-on setting for me to enable p2p streaming! Thanks Steve
                  I have the Beyond XBMC.
                  Go to system of xbmc then addons/ install from zip/ fusion / movies-tv and install the "repository.p2p"
                  After the installation enable the p2p addon from the get addons.
                  Run this addon and it automatically downloads sopcast and ace apk. Install both.
                  You'll need to run Acestream before XBMC.
                  For sopcast find the wiki (from google) and change some permissions of sopcast.
                    For LivestreamsMod addon: go to add source, choose URL and add this: http://gg.gg/vcx7xbmcQQ - then add source. You'll need to start Acestream engine before XBMC and set permisions to sopcast ( go to Sopclient file, and set permisions like this: rwx-rwx-rwx)... this is for streams that use this engine like Arenavision and Bloodzeed for e.g.
                    For IPTV add this as list: http://64.111.125.133/lista_iptv.php - Use Wondershare Player, download it, go to IPTV Settings and choose System Select.... enjoy nice quality video streaming...
                      p2p addon
                      Thanks and4468, I will give it ago tomorrow night! I am running JustXBMC so I hope it will work the same as BeyondXBMC. :-)
                        Thanks dude that is an excellent list!. Can I use wondershare in xbmc as well?
                          playing Sopcast through XBMC
                          Hi and4468,
                          I have now managed to get Acestream working through xbmc thanks :-) but can't get Sopcast to work through xbmc! Please could you help me.
                          Thanks Steve
                            Hi and4468,
                            Thanks Steve
                            Goto this link : code.google.com/p/p2p-strm/wiki/P2PstreamsAndroidENG
                              Hi and4468,
                              Thanks Steve
                              how did you get it working?
                              can you please let me know how you did it?
