This recovery is built from source with a little modification to fully support Rockchip's, in a way that it can backup and restore any partition without problems.
You can know more about TWRP in here.
I have built a number of generic images. This images requires a valid kernel in the kernel partition, otherwise they won't work.
Keep in mind that the devices aren't all the same, this images were built with the most common characteristics.
This images are identified in the name by Width x Height _ SoC type _ KitKat . img
TWRP 540x960 rk3188
TWRP 800x480 rk291x
TWRP 800x480 rk292x
TWRP 800x480 rk3026
TWRP 800x480 rk3066
TWRP 800x1280 rk3066
TWRP 800x1280 rk3188
TWRP 800x1280 rk3188 KitKat
TWRP 1024x600 rk292x
TWRP 1024x600 rk3026
TWRP 1024x600 rk3066
TWRP 1024x600 rk3188
TWRP 1024x600 rk3188 KitKat
TWRP 1280x800 rk3066
TWRP 1280x800 rk3188
TWRP 1280x800 rk3188 KitKat
TWRP 1920x1200 rk3188
TWRP 1920x1200 rk3188 KitKat
Here's 2 flashable theme's.
1280x720
1920x1080
How to install
1) I have made a small batch script, that flashes TWRP without the need to enter in bootloader mode. The only requirements are that you have ADB setup and have a insecure boot.img (ADB Shell run's as root). If are running a FreakTab rom, them you have it. If you aren't running one, well you should.
Download this script, and unzip it. Rename whatever recovery you downloaded to recovery.img and place it inside the recovery folder. Connect device, with USB Debug checked and double click installer.bat. Profit.
2) You can use one of the Rockchip's flashing tool's. On the flashtool select the recovery.img of your choice, confirm offset location, if you are uncertain use the same parameter file that you used to flash the Rom. Connect the device in bootloader mode to the PC, DON'T ERASE IDB, and press Run. Enjoy.
Support thread
Please respect my work and don't mirror my files. Instead redirect people to this thread. Thanks.
If you are that happy
You can buy me a beer here.
