Help
    Help
    Hi
    I am looking to buy Android type tv box or stick any suggestions pls ?? i am really confused what to buy etc ..
    cheers
    Lol..
    Not even a price range.. or a hint.. on what you seek to do with the unit
    My best buyes.. where ( from low to high price )
    cs918 -rk3188 -2gb ram -from **** (cheap and has great freaktab support)
    Cs918s -allwinner a31s -2gb ram -from dealprime ( no real support, but out-off-the box a great unit with spmc/xbmc)
    Minix x7 -rk3188 -2gb ram -from geekbuying (great support)
      Thanks for the quick reply .. Sorry mate price range wise less than £100 - £110
      i have read so many reveiws but got confused.
      i was looking for cs918 but there alot of different brands but same MB
      i am considering either X7 or cs918 any suggestions pls ?
        Buy a Ugoos UM2 very good Device with Good Wifi and Support.
        Neomode
          Thnx neomode can I able to get 1080 or 720 picture quality ?
            AW: Help
            Yes you can. Right now I Work on a Custom ROM for it.
            Neomode
              Good stuff guys thanks for ur help and support... Neomode can't wait to flash ur new custom rom ...Once again thnx
