I have a big problem and spent the whole afternoon trying to solve it:
While trying to flash to the currend neomode ROM the pc decided to not like the flashing process and the app crashed. Not I seem to have a half rom on my stick. This renders the stick unusable.
If I plug it in to the TV the red light is lighting up, but that's it. Nothing happens on the screen. If I hold down the reset button and plug it into the PC it is again lighting up. But my PC is failing to recognize the stick with "Unknown USB Device (Failed to receive device description)" << Translated from a german errormessage, might be a bit different on an english system.
I then went through different Forums and tried the method of short circuiting the pins 8 and 9 of the Big chip on the back of the thing. The result was the same. I even tried both versions of that trick (use the DC Port for short circuiting it and then plug it back into the pc // short circuit while pluggin into the pc).
Does anyone have any further Ideas? I'm really sad that my nice weekend project turned out to be a desaster.
I would be grateful for any Idea.
Regards
Ulf
