T-R42 PROBLEMS
    T-R42 PROBLEMS
    I have T-R42 (S/N: T_R42xxxxxxxxxx), with original rom and unrooted, for one week and I have several problems:
    1. Wifi download speed is 0,4MB. When I restart my device DL speed is 7-8mb, but after 2 minutes speed drops to 0.4mb and stays down there.
    2. Device keep unmounting internal storage. Then I have to go to setting and mounted back. This does for no reason.
    Please help me with ideas. Thank you
    Sadly.. you need to open-up the box.. to figure-out what you have
    See
    Under the device are 4 rubber-pads, if you re-move the rubber
    There are screws.. to open-up-the-box
    Goodluck
      What will that help me if I open my device? Are my problems hardware or software related?
      What is your experience with geekbuying resolving problems?
        You need to open up your device to find out what wifi chipset you have. Once you know the chipset number you could flash some of the very nice custom rom from this site and very possible it will help your issues. I used to have storage disconnected and after flashing the 1.2.4 wasser rom, my issue resolved. I don't have issue with Wifi either with stock or custom rom so possible the compatibility with your router, to figure this out try another router from your family or friends' house. Finally, you could open up your device without breaking your warranty since there's no "seal tape" to indicate that you opened it.
          I will open a Case to see what version I have.
          I tried to connect to my 3g network(phone set as router) and I get same result, max 0,42Mbps. Strange thing is that T-R42 download speed is 7Mbps after reeboot, but after 2 minutes drops to 0,42Mbps, every time :-(
            I reason I recommended to go to someone else house is to eliminate issue with frequency interference. Possible there's interference of some sort in your house and the device. This is usually the case with speed degrading. Also try go into wifi advance and check minimize wifi battery see if it make any differences (lack of power supply). Also try flash Wasser 1.2.4 since I found it's the best rom/kernel to date with our T-R42.
              ok I will try to connect device at another place. But I think this is not the problem, because Wifi works exellent for 2min and then drops to 0,42.
              I will try with 1.2.4 and we will see if problem with wifi is resolve.
                I opened case and I have V2.0.
                  B351 v2.0 ?
                  If yes.. see
                  Here you can find many firmwares for many devices
                  Goodluck
                    I had original rom and I install Wasser rom 1.2.5 but without kernel. Now i have "no signal" when I connect device to TV. :-(
                    On this webpage from link are all Rom that has B351 BT V2.0 for T-R42?
                      You have no signal as you have not flashed kernel
                      You need to choose a boot kernel, 720p or 1080p. Then you need to use the T-R42 New kernel for kernel img then Flash. I have B351 v2.0 and wasser 1.2.5 works great. Wifi too
                      Kernel http://www.freaktab.com/showthread.p...asser-firmware
                      Edit. No need to flash all firmware again. Just load the T-R42 New kernel and flash that file only. Your box then should give you signal on TV
                        Thank you for your advice, I will try that. But links for Kernels are dead. Can you send me kernel to my email or upload it to web?
                          I have just uploaded them for some other guys, here you go
                          720p New http://www75.zippyshare.com/v/68113765/file.html
                          1080p New http://www24.zippyshare.com/v/37575089/file.html
                          choose which one you want to use, I use 1080p (along with 1080p boot) and works great. Good luck
                            Once again, thank you for your help. Tommorow I will flash my device with kernel and report back if it works.
                              No problem. All the best!
