the most annoying issue ive come across is the fact most stuff ( are desgined for devices with a "hard" back/home key" so they make the program in fullscreen, )
such as games, so litreally for example if you play ( little empire or watch bbc iplayer, ) theres no exit .
so the only way is too ( reset or close the screen to unlock then quickly try press the home screen before it wakes to the "running app"
suggestion > is there a way to keep task bar open (on top always ) ?
or a way to program the current ( hold power button > reboot > (add function "Home Screen")
?? or any tips for full screen apps i.e tower defense games, ( its same in compaitabily mode )
