I've built and tested Ubuntu 12.04.4 and Ubuntu 14.04.0 on RK3066 and RK3188 devices. I've tested against popular kernels, modules and firmware which are included on the GitHub site. I've also had good luck building kernels with Marvin which I've documented as well. If you want to dual boot Android/Linux make sure you flash a ROM that supports /etc/init.d. After flashing the initial ROM everything else can be done in Linux without the need for Windows.
Report issues on GitHub.
