i own a T-R42 (CPU RK3188, board version B351 V1.1)
I flashed a custom rom and since then i am no more able to reactivate the wifi
I tried many other custom roms and stock roms, but i have always the same behavior:
When from the settings i try to turn it on, it stays on for a few seconds ( no wireless network is shown ), and then it goes off
The last rom i flashed is this (from Geekbuying):
RK3188(T)_BOX_SZTENA_BX09_B351_AP6210_20130927.img
This is the logcat that is printed when i try to turn my wifi on:
(using command adb logcat on terminal emulator session)
D/WifiHW ( 368): Read wifi chip type OK ! wifi_chip_type = RK901
D/WifiHW ( 368): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
D/BluetoothAdapterService(1097373104)( 811): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@ 4168aef0
D/WifiService( 368): setWifiEnabled: true pid=870, uid=1000
D/AudioHardwareALSA( 109): Audio exiting sandby will open audio device
D/AudioHardwareALSA( 109): AudioStreamOutALSA::standby().....
D/WifiHW ( 368): wifi_load_driver: driver load failed
D/WifiHW ( 368): Unable to unload driver module "wlan": No such file or directory
E/WifiStateMachine( 368): Failed to load driver!
E/WifiStateMachine( 368): DriverFailedState
i checked that under system/lib/modules do exist these files:
rkwifi.ko
wlan.ko
both with owner 'root', group 'root' and permissions 644
(after flashing this stock rom i dont have more root permissions so now i cant overwrite or move them)
Could someone owner of T-R42 open a terminal emulator session and
send me what is printed by the command 'adb logcat' when he tries to turn on wifi?
Just to know which wifi_chip_type is reported by devices with working wifi...
Or perhaps can someone give me some hints on how to discover the right wifi drivers for my device?
I will be very grateful to who help me to reactivate my wifi... perhaps i will send him some prize....
Thanks!
